So my turbo is going, going, soon to be gone...
I have a 2003 M35 Stagea, 120xxx km's. Stock - except for some mad-as wheel nuts!
My mechanic has told me that to rebuild the turbo will be around the 2.5k mark based on the following:
  • Engine removal (as the turbo cannot be reached any other way)
  • Rebuild the turbo (as a replacement from Nissan will be too expensive)
  • Refit the new turbo
  • Replace Engine
So my question to all you fellow Stag drivers is this:
Is the price/quote correct & must the engine be removed to replace/rebuild the standard turbo?
https://www.sau.com.au/forums/topic/401832-rebuild-or-replace-m35-turbo/
  • Replies 55
Posted Images
Lol... find a new mechanic.
Where do you live? There are people in melb and Sydney who will quite happily help you out, and combined I would have to say have removed and/or refitted/ replaced upwards of 15 turbos, at a guess.
Its not an engine out.
Hypergear along with some other companies can rebuild the turbo.
  • Replace Engine
You don't need the engine out....makes it a little easier but there is no need! Hypergear can rebuild a turbo to your from $880 being the cheapest. I can pull it in and out for under $900. Not including oil and oil filter or any other damage parts.
I'm in NSW
Scott's the same price but in Vic I think
Hi All,
Thanks for the feedback.. Im in VIC - South East.
The mechanic Ive used has been always reliable for my previous R32 and now my M35...
Will get in contact with Scott nm35.
Also - any ideas what causes the turbo to fail? Ive never owned a car that hasn't been turbocharged and this is the first turbo to fail... At 120xxx km's I would have thought this is a little early for failure of what I would consider a fairly major part..
Edited by WTBN
It's a replacement part at 100k km I've heard.
Your car might well have more than what's on the clock. Biggest killer is lack of oil, due to blocked oil restriction banjo. Scotty will sort you out, your in good hands
You got to 120k? Lucky you. Mine was done at about 75K mark and was engine out job. Mechanic couldn't remove the bolts otherwise even with special tool he bought for the job. Cost an arm and a leg but has performed well since. Was reconned by an outfit in Nelson, SI. The stock unit is lightweight.
I hope the mechanics you use are cleaning out the banjo bolt or drilling it out larger, otherwise you could have another failure down the track. There is no way a legitimate 75k turbo will have failed if the oil supply hasn't blocked somehow.
Engine out? lol. Bugger that, unless you blow a head gasket. :(
What did yours end up costing in total STAG250? I have a feeling the mechanic's quote (2.5k) above was very low for an engine out job...
My advice is to be careful where you go...
I got ripped off hard for what I thought was an engine out high-flow rebuild, turns out they just f**ked around getting it in and out with the engine remaining in car. This all by a northern beaches franchise of a widespread automotive mechanic company recommend by my warranty company who then tried to take them for a walk (approaching $5k) and shot himself in the foot saying it was my fault it broke... I ended up forking out more than $3K, and that was after a payout of approx $1200 (1/3rd of what it should have been). I believe it was a sierra 2 rebuild, but when I asked for info on what they actually put in I got donuts! The receipt said "turbo up spec rebuild $(bullsh*t).00" Also no info if they drilled the banjo out or not...
My advice would be to shop around, needless to say I'm a rather bitter about my experience... still haven't fully recovered financially, if I could go back I wouldn't have wasted my time and money dealing with this workshop and warranty cr*p and gone straight to Jetwreck for a no BS, cheaper alternative from someone that actually knows a thing or two about this car. I'd probably know exactly what work was done and equipment went into the car too...
Edited by NickM91
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
