Hey guys,
Needing to clear out the garage to make some space,
got a diff centre from my 2000 model 34gtt that i dont need, replaced it with a OS giken 2way
$350.00 and ill throw in free postage as you will be doing me a huge favor in getting rid of it.
Pm me or txt (let me know u are off sau)
0424703213
Cheers Mick
Can post up pics if needed, if you do just ask away!!
https://www.sau.com.au/forums/topic/401856-fs-r34-gtt-diff-centre/
