  • Replies 112
links to results?
That's what I'm after , you said plenty of results show losses in power and response when a plazmaman plenum has been put on , I want to see these results as I can't find anything bad on them
http://www.skylinesaustralia.com/forums/topic/330619-a-boys-love-for-his-rb20/
In there somewhere
Lol...i miss you when your not around Zeb...
while I won't deny plazmaman quality, I'm not justifying the premium..
So sorry plazmafans but soon as that Chinese junk copy comes out for ima gunna jump on dat shit..
Your not the only one mate! Praaazman + wrinkle black paint and on it will go!
Yeh he complains but he kept the stock throttle body for one , with his upgrades there is no way he shoulf still be running that..... and yhere is also someone in that forum sayin he got quicker spool, better response, a minor hp gain and no bleed off at higher revs ....... And there is no dyno sheets anyways , thats not results btw
get two! :cheers: ill buy the booze we will fit them at the same time. ebay all the way for me!
Lol we all know deep down that pretty much everyone that goes down ffp plenum route is doing for engine bay points. I bet if the same results were to be achieved by say a aftermarket cross over plenum for the same proce no one would buy it because simply spending like 1000 for something that you might get a slight improvement but still have to trade off with some reponse or mid range cannot be justfied.
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
