with all the new turbos ( i.e: bilelt technology) arent the -9 outdated in the way that you can get the same response but with better power?
What you're referring to there is just a type of material production process. I think you may be referring to newer materials / machining processes in todays turbos?
I was under the impression that the -9's weren't too bad in that area.
Mine may be laggy at the mo....but there are some graphs on here that are pure porn! :)
Did it go to the cat or get sucked back in?
Nope :-)
Agreed. My guess is machining wheels from billet is just a low volume production method, so would be good for prototyping. discopotato would know....
To answer the question about -9's being outdated. Garret -5, -7, -9, -10 all use exhaust wheels cast from Inconel (mix of nickel steel etc). To get better response from these same turbos, titanium aluminide could be used to save about 30% weight vs inconel. The Garrett GTX range use steel billet wheels, they should be stronger (vs the casting process) and have better flow (updated wheel design) but billet steel doesn't do much for weight, they may even weigh more than the old Inconel wheels.
exactly what I was refering too, if it they flow better by 10-15% ( garret's figure), this should result in better perofrmance no?
BTW, I own myself a pair of -9 just wondering if 3 years later, theres not better turbos out there ( lots of talk about precision turbo beeing as responsive as twin but with power of single)
Hey Cobra, would you mind sharing how you went with your -9's? Mine are looking much more promising now, lighting the rears up in 2nd and 3rd so am very keen on getting my front diff back up and running and a retune!
At what RPMs would you be making say, 1 bar and fullboost?
curious what tyres u running? I can't get my rears to light up unless I rev and launch, but not 2nd n 3rd
Well it is just RWD now with front drive shaft disconnected because of buggered diff. The tyres are near new Federals, 255 45's with just 30psi in them to give it a bit of a better contact patch while it's just RWD and can't shift power anywhere.
Yeh this is just around 4000-4500 when the turbos really ramp up hard. Realy want my front diff going again so that I can feel all of the power not just up to where it breaks traction. It was quite a mess when I had 35psi in the tires - it hardly put any down.
Also, mine will only do it in 2nd and 3rd....the tune is not good enough to make it do it in 1st with just a normal non stalled up / spiked launch. My R33 N1's were the same....1st was only there for one reason and that's to get the car into 2nd :D
....unless you bought the turbos up to speed with a rolling start at about 3000rpm and then launched it, then it went stupid in all gears except 4th and 5th....although 4th was a bit on edge especially on bumps or crests..
does this mean you have figured out fixing the rear diff or just going to get the front done and do back later
if you still have no love from the -9s you could try getting the rear housings off your stock turbos machined to fit the -9s, that would improve response just kill top end a bit
LOL, so true :P
Um nah the rear one is still worn but I let the tyres down and made sure both sides are very even. Keeps it straight for longer lol.
Yeh I'll be fixing the front diff first and then sorting out what to do with the rear.
Yeh you do make a good point there...I reckon once you've been through a heap of turbos you'll know exactly what you want and could make up a hybrid setup. But I would like to give these -9's one last chance with re-tune at Godzilla. If I still don't like the feel after that I'll probably strip the gear off and focus on more important matters in life ;-) 8 years worth of blowing money on Skylines is starting to get to me :unsure:
But one thing is already very apparant and that is, sure enough they may be quite laggy in the city (at this stage) but when you're out on the open roads they can really hawl some ass. Quite impressive how they'll pull in 3rd and 4th....a LOT better than what my ceramics were capable off.
...hopefully with a re-tune I'll get a good average between the past ceramics performance and the current mid-to-topend performance of the 9's.
get them to dial in cam gears for response, I sent you some settings awhile back, that would be a good starting point for alround use with stock cams
I've been spending money on these things for over 10 years now, but would much prefer spending money on these then drugs, smokes or alcohol, and when attending events like texi, its something I can do with my son when he is old enough
You and your words of wisdom ;) Yeh I'll be running those degree settings past him and see what he can do.
Well from what I've seen you've had some pretty impressive results too...especially those with your ceramics that's not a bad effort. I think the most that I ever made with my ceramics was like 354hp and then 375hp with the 33 N1's.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
