Hey guys
I got a series 3 r31 and looking to do a ls1 conversion, jist wondering if anyone knows if the is a conversion kit available and where I can get it from or what is needed to drop one in, I know there is s13 kits etc but have not seen one for r31
Cheers
https://www.sau.com.au/forums/topic/403271-ls1-into-r31/
well done on thinking outside the box! anything has to be better than a NA RB30E but doubt that you will get it passed without upgrading the brakes and other things too, gonna cost ya alot of bucks as its unlikely there will be an off the shelf fitting kit available
Edited by StevenCJR31
https://www.sau.com.au/forums/topic/403271-ls1-into-r31/#findComment-6413283
In Perth dude, I just wanna know if there are kits available if car gets stickered ill track it
You might be right over there, they have a system that is at least reasonable :)
There is no off-shelf kit that I'm aware of, it'll be all custom fab work as there aren't that many LS1s in R31's to begin with, I recall seeing maybe 2 or 3 cars with one in them over the years and that's about it.
This is probably as good as you'll get info wise:
http://www.skylinesaustralia.com/forums/topic/187852-r32-ls1-conversion/
This thread has no real useful information (but it's R31 with a LS1):
http://www.skylinesaustralia.com/forums/topic/355725-ls1r31/
https://www.sau.com.au/forums/topic/403271-ls1-into-r31/#findComment-6413304
i spoke to the guy in s.a with this conversion, all that was needed was custom tailshaft, gearbox crossmember and engine to mounts were custom. I think he had standard engine mounts from the crossmember part. very easy from what i saw. I am doing this conversion myself on a r32
there is a place here in sa that makes mounts for ls1 conversions, he is on ebay. best bet would be mounts for the vl 6 cyl range.
hope this helps :cheers:
Edited by rb20-into-mr30=
https://www.sau.com.au/forums/topic/403271-ls1-into-r31/#findComment-6414570
In an R32 you can go up to a 7L NA engine or 4.5L turbo charged if you get it appropriately engineered.
I imagine an R31 is slightly heavier/the same so I imagine similar limits, I read this on the application to modify vehicle regulations.
Not quite correct... It'd be around 6500cc (maybe less, depends on model).
VSB 14
Either way each state then carries it's own laws on the matter so it could be less again (or impossible).
Vic being a VASS Engineers, I've spoke with some a few years back and i did ask a similar question. They said no way would they be letting an injected V8 pass in a lighter car than it came with, especially given kw increases... So as i said earlier it comes down to the state you live in, and knowing the laws and contacting the engineer first to find out what they will need before doing it. could even depend on the engineer you get and if they are willing or not!
https://www.sau.com.au/forums/topic/403271-ls1-into-r31/#findComment-6415758
garage 7 in S.A wouldnt be able to help would they? i got all the stuff i need for s13 front set up from them they seem to know abit about 31's you dont know the guys name on ebay so i can search him or what i search under??
all this helps guys cheers!!
https://www.sau.com.au/forums/topic/403271-ls1-into-r31/#findComment-6416043
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
