  • Replies 53
not shutdown at all mate, just trying to share what I've learned over years of running a race car, and watching other people trying to race/drift/rally seriously.
the full on stuff is hgely expensive, but there are cheap ways to give your car a thrashing instead
Then you will wish you should have entered :)
I would haha. just cant afford to fix anything if anything was to happen or needs replacing.
Legit question, would I need to pay for entry as well as AASA license if I was to just spec?
No screamer = no power for me, but still gunna go Texi and make an ass of myself... Jut enter your car and drive to whatever limit you feel? You don't have to drift or do skids, just enjoy and learn your car :)
I'll spec the first one so I can get a little intro to what texi really is and know what to expect for next time! Where on these forums can I find texi events?
I have no idea what Texi is, I'm just going out to have fun and make an ass of myself :D
The events are under NSW then events, has all the cruises, dinners, races, Texi etc etc.... It's a whole lot of awesome :yes:
http://www.skylinesaustralia.com/forums/topic/331711-s-a-u-n-s-w-club-events/
Gets updated every now and then - if you subscribe, you'll get emails (I think?)
http://www.skylinesaustralia.com/forums/topic/349895-so-youve-never-done-texi-before/
We plonk a course down in witches hats, you get it on a piece of paper - memorise as best you can, drive it, have fun, if you f**k it up, slam pedal to floor for smokeshow :)
We've had a Barina Spark out there before, just going for times - he beat me once in the battles in the wet :( NO TRACTION!
Here's an example of a past course:
lol....
p.s. unless you get a engine cutout defender thingo ie: stops the car from stalling when handbrake is applied fast you cant use the handbrake in an auto without going into neutral, using handbrake then going back into gear.
What? Is this a skyline thing or something?
Every auto I've driven avoids stalling when you lock the drive wheels with this thing called a stall converter/torque converter... It works similar to putting the clutch in when you pull the hand brake on a manual... Advantage to auto, keep your foot on the throttle... So long as your handbrake can hold the power the engine is putting out...
i spectated my first texi, cause i only owned my car for a few weeks and it was soooooooo shit, had to wait 4 months for the next one, seriously, i would have paid 35 dollars for just 1 run, wont do shit to your car and is mad fun.
you dont have to do burnouts or handbrakies, just drive, learn how far you can turn your car before it slides, learn how fast it can change directions, its a great thing to do before you go on a track and on the public roads!!
but its your own decision dude.
you can hit me up for a ride, but youll have to fight between my gf and my mate :P
haha thanks for the offer man! much appreciated. i don't think i'll be able to head out to this texi on the 15th. planned a day out with my mates to penrith for some lunch. would be bit late by the time i rock up
Pffft, the Nirimba campus is only half an hour away from Penrith, so come early, watch people having fun (and even jump in for a ride with someone), then head to lunch.
Problem solved!
haha i already thought about that, but im heading a cruise to penrith at 11am cause no one has GPS but me...
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
