  • Replies 53
not shutdown at all mate, just trying to share what I've learned over years of running a race car, and watching other people trying to race/drift/rally seriously.
the full on stuff is hgely expensive, but there are cheap ways to give your car a thrashing instead
Then you will wish you should have entered :)
I would haha. just cant afford to fix anything if anything was to happen or needs replacing.
Legit question, would I need to pay for entry as well as AASA license if I was to just spec?
No screamer = no power for me, but still gunna go Texi and make an ass of myself... Jut enter your car and drive to whatever limit you feel? You don't have to drift or do skids, just enjoy and learn your car :)
I'll spec the first one so I can get a little intro to what texi really is and know what to expect for next time! Where on these forums can I find texi events?
I have no idea what Texi is, I'm just going out to have fun and make an ass of myself :D
The events are under NSW then events, has all the cruises, dinners, races, Texi etc etc.... It's a whole lot of awesome :yes:
http://www.skylinesaustralia.com/forums/topic/331711-s-a-u-n-s-w-club-events/
Gets updated every now and then - if you subscribe, you'll get emails (I think?)
http://www.skylinesaustralia.com/forums/topic/349895-so-youve-never-done-texi-before/
We plonk a course down in witches hats, you get it on a piece of paper - memorise as best you can, drive it, have fun, if you f**k it up, slam pedal to floor for smokeshow :)
We've had a Barina Spark out there before, just going for times - he beat me once in the battles in the wet :( NO TRACTION!
Here's an example of a past course:
lol....
p.s. unless you get a engine cutout defender thingo ie: stops the car from stalling when handbrake is applied fast you cant use the handbrake in an auto without going into neutral, using handbrake then going back into gear.
What? Is this a skyline thing or something?
Every auto I've driven avoids stalling when you lock the drive wheels with this thing called a stall converter/torque converter... It works similar to putting the clutch in when you pull the hand brake on a manual... Advantage to auto, keep your foot on the throttle... So long as your handbrake can hold the power the engine is putting out...
i spectated my first texi, cause i only owned my car for a few weeks and it was soooooooo shit, had to wait 4 months for the next one, seriously, i would have paid 35 dollars for just 1 run, wont do shit to your car and is mad fun.
you dont have to do burnouts or handbrakies, just drive, learn how far you can turn your car before it slides, learn how fast it can change directions, its a great thing to do before you go on a track and on the public roads!!
but its your own decision dude.
you can hit me up for a ride, but youll have to fight between my gf and my mate :P
haha thanks for the offer man! much appreciated. i don't think i'll be able to head out to this texi on the 15th. planned a day out with my mates to penrith for some lunch. would be bit late by the time i rock up
Pffft, the Nirimba campus is only half an hour away from Penrith, so come early, watch people having fun (and even jump in for a ride with someone), then head to lunch.
Problem solved!
haha i already thought about that, but im heading a cruise to penrith at 11am cause no one has GPS but me...
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
