I'm looking at extracting a bit more power out of GTR. After blowing the turbos at my first track day, I have done the following upgrades:
  • Installed Garrett -7's, dumps & front pipes
  • Vipec & tuned @ 260kw on 17psi (standard injectors)
  • FPR, pods, boost controller, exhaust already installed
  • Some other shit I can't remember :P
I would like to reach about 300-330kw safely, but more importantly I want the power to come on earlier. The turbo spools up between 3400rpm to 5000rpm. Is there any way to get it to kick in earlier? Aside from bigger injectors, what else would you guys recommend to get more power out of it without opening up the engine. Also, is there any advantageto switching to E85?
Cheers
https://www.sau.com.au/forums/topic/403940-getting-more-power-out-of-7s/
  • Replies 85
Im pretty sure if your getting full boost at 5k rpm then you have something wrong or you have to go and get a different tuner.
Do the basic shit!
Bigger injectors
Fuel pump
Dump pipes
Big cat
Good exhaust
Mainly GOOD TUNER!
No reason why you couldnt get 300 if you do all that!
I also forgot I have a walbro fuel pump. What's the benefit of E85? I also should've mentioned this car is for the track only if that makes any difference.
I'm trying to find a dyno sheet from the last tune hopefully that will explain things a bit better.
cam gears
injectors
boost
tune
stock airbox
Whilst there are a whole swag of other parts you could buy... spending anything more realistically than the above list with those turbos, will not give you worthwhile gains for the money you'll need to spend.
I make around 300kw on that boost with -7s, and that boost hits at around 4000rpm. But you wont do it with stock injectors at stock rail pressure and stock cat/catback. So get 550cc or similar injectors, and a 100 or 200 cell metal cat and 3 or 3.5in catback. Cam gears can make the turbos spool earlier, and if you change them you'll need to tune, so you might as well get them now and have it all tuned together.
-7 come with new adjustable actuators, but they may need more pre-load. IIRC 10mm is a good starting point.
  • 4 months later...
Car is getting ready to go for a tune. At this stage I can't really afford switching to E85, so I was going to get a tune with the following items:
  • Bigger injectors (Bosch 750cc)
  • adj cam gears
  • tune
  • tomei poncams
Firstly, which type poncams should I go for? Secondly, are Bosch injectors any good? They're only $480 from ebay. And thirdly, are the cams useful in this setup? I probably should've mentioned the car already has 3.5inch exhaust and modified cat. Are there any other mods that might be more useful?
Thanks guys.
I don't know that much about the cams, from what i've read the poncam type b's would be suitable. Wait for someone with more knowledge to have a say on that though...
As for the exhaust, you mentioned you have done the cat and catback, by "modified cat" do you mean gutted? Cos if its a track car maybe you could just run a straight pipe in its place. What about front pipes? Those would make a big difference.
For -7s, no need for cams of some sort, stock cams are more than enough. Just need to arm it with adjustable cam gears.
On pump, -7s will do 300-330-ish kw at wheels depending on boost, motor condition.
The poncams are going to give you very little for a lot of expense - they're really a waste. Also, you shouldn't need to modify a cat...
If you dont get ~320 on 20-22 psi, then you have some troubleshooting to do. Eg, drop exhaust to check if its restrictive, compression check, etc.
  • adj cam gears
  • tune
  • tomei poncams
Thanks guys.
ditch poncams, new Walbro pump is like $180-190 i think? shove that in, and you're E85 ready - you've got everything else, and if you're going to get injectors, just get some 1000's and be done with it, although i think you'ld be ok with E85 and 750's. And it's a track car, even more reason to go E85, so much more protection available via the fuel.
the "can't afford" line doens't really make any sense?
I keep forgetting they make injectors to drop in for E85. So fuel lines don't need to be changed for bigger fittings or anything? I was also told the tune costs about $1800 for a flex fuel.
I'll look into pricing, am keen to switch to e85 for sure.
Also, it has a walbro already installed :)
Doing a flex fuel tune can be done depending on the ECU you have,
ID 1000's are great for $700 odd delivered, Give Tu Speed a call, Don't forget you will need adapters to fit STD rail, Call Tuff car parts for a set.
stock dumps are good if you can your hands on R34 ones, FPR are really needed... So ive heard.
you say you have exhaust set up already, Make sure its a free flowing as possible, What are current specs do you know? Either way. Start with big injectors and a tune. Wind the boost up to 20 psi + and should be happy days.
The newer e85 400L walbro flows twice what your 342 walbro will. They are also designed to be e85 friendly and come with sealed connectors.
Bosch ev14 1000's can be had for $600 including the adapters and plug tails locally, with warranty. ;)
^ hence i don't understand the affordability aspect... you have to do these things anyway, or already have...
you don't need a 'flex fuel' tune - you said it's a track car, so just leave it on an E85 tune, simply.
'flex fuel' is ability to run any mixture of 98/E85 - required ethanol sensors etc, this is not at all needed from what the OP has posted. Just needs an E85 tune and happy days :)
Yeah you're probably right, spoke to a few tuners and looks like the way to go. Are the stock fuel lines an issue?
This is what I've costed for so far:
  • E85 tune - $1300
  • Bosch 1000cc injectors - $600
  • adj cam gears - not sure whether to get ISC $200 ones for tomei ones for $380
  • Walbro 400lt fuel pump - $275
Have I missed anything? Thanks for the help guys :)
Race Pace make some great adjustable cam gears, they modified the stock ones and from i understand, it's a more durable base to start from. You could go that route, you'd either have to see if they have any in stock, or just send them yours.
Red R racing probably could modify stock cam gears as well. No real $$ advantage over new, the ISC definitely seem cheaper than what i paid for RP to modify mine
stock lines are fine in terms of concerns about degredation etc (not an issue)
i'm not 100% if there is concerns with a 'capacity' issue? i'm wouldn't think there would be an issue - i made near 300rwkw on my prev GT-T with E85 and stock lines, 98 car. Still fine on high % ethanol after 4-5 years
    • att.4QNbuJlz_gNZPFBGFqeEvxSUHXkGt7z40V59MrtXTPg.mp4
    • Plan on the day will be to park trackside. Depending on space availability we will try put a small shade tent and a few of the cars on top of the hill inside turn 3, this is an easy to get to parking area with views of Turn 2, Turn 3, Turn 4 and Turn 5 and limited other pieces of the view around the track. IMPORTANT NOTE! One consideration from previous years is from memory the trackside parking sells out before the admission tickets, for that reason I encourage anyone planning on coming to buy tickets for parking now via the official website; https://www.worldtimeattack.com/ The type of parking you are looking for is 2 Day Park & View (Access Around Venue) Vehicle Pass Only Please note this does not include admission to the event itself, remember to grab that also, and kids under 12 get in for free!
    • This is going to be a mid week evening cruise. Come along and join us for a drive out to Palm Beach. This is a change of event plans after talking to some of the older members of the club. SAU NSW is planning on hitting Old Pac again shortly, stay tuned for details. When: Thursday 26th of June Time: 7:30pm meet/8:00pm departure/10:00pm finish Meet: Spit West Car Park / Spit Rd Mosman NSW 2088 Destination: Palm Beach Public Parking / 16 Ocean Rd Palm Beach NSW 2108 Up to date information as always can be found on the events page of our website, the link for this event is https://www.saunsw.com.au/events/palm-beach-cruise There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • Good time for a carbon roof
    • Not in any way aroused by any of those, except maybe the big AMGs. And that would break my never a Euro, ever, rule.
