Hay Kate!
Welcome, hope you enjoy your stay. Lots and lots of info in here. If in doubt use the search function and you should find some info. Can recommend people to work on your car too should something need attention.
Dont worry about the trolls. Plenty here. Provide the Lolz mostly.
https://www.sau.com.au/forums/topic/404603-newbie~~~/#findComment-6446185
Haha no problem, thanks! Yes that would have been I remember I saw your post in spot the stagea.. :) looking at going to the cruise on 22nd, should be good.
You will find a lot of usefull threads on here and the meets are great too....
https://www.sau.com.au/forums/topic/404603-newbie~~~/#findComment-6446721
had a quick look at your profile, definately need to put some pics up (of your car please) and also yes i'm still i believe the youngest active member on here at 22 yay!! glad to see i'm not the only young person who likes these cars, my mates all give me so much s*** for driving a wagon, even though i need the space for work, and for my son.
https://www.sau.com.au/forums/topic/404603-newbie~~~/#findComment-6447212
Oooh, I could be younger :-)
I'm 23 in November
Also, welcome to the stagea girl
https://www.sau.com.au/forums/topic/404603-newbie~~~/#findComment-6447524
    • My 3.8 kW system (when new, not so much nearly 20 yrs later) will do 21 kWh per day (best few months of the year), and that's with an afternoon shading issue. So it really could/should be able to do maybe 24. So a 6.6 kW system probably cannot fill a 40ish kWh battery from scratch, but then it is very unlikely to ever need to. Let's presume that you use 10-15 kWh during the day and stash the rest. So long as the battery isn't drawn down below ~50%, it'll be fine. And that draw down presumes using 20 kWh overnight, which is a reasonably heavy draw. So that seems reasonable. The 40kWh will be good for extended outages, and very bad days where you get almost no generation for a day or two. Might struggle to top it all the way back up after it gets pulled all the way down though. I'd think you'd probably want about 10 kW of panels to make life a little easier, wrt keeping a 40 kWh battery charged. But then....does it really need to be at 100% every day? Probably not.
    • Am I wrong in thinking that there is a hell of a lot of battery storage for a 6.6 feed into it Your battery is around 4 times bigger than the battery that is going into my place in a week, but I have nearly twice the feed Will the batteries actually ever get fully charged? School me on the science bitches
    • Wow ELVIS. You have an....interesting approach to conversation. Did you not notice that I wasn't talking to you?
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
