Not sure on the bar yet, I can't see how the handling can get any better actually. 2nd gear coming out of MG corner at PI and all 4 just gripped and took off, no front pushing and no rear stepping out, totally neutral and far beyond my expectations.
You may have a hard time getting the GT35 to fit as the HKS flange adapter steps down to T2 an I'm guessing your GT35 rear is T3.
  • Replies 182
So you havnt got this bar yet and already you feel with FI you have great grip? I have white line sways, endlinks, bc racing br coils, RS3.. no rear or front strut bars..
as for turbo i havnt got it yet, but one i was looking at was off a xr6 so nto sure on T size... is that what you make an adapter for?
I've got all of that plus a front strut brace, and mine turns in incredibly. Might be worth looking at?
AWD ftw. I don't think it would be that neutral in rear drive. lol.
For a turbo like that I would at least need the turbo here to jig it up, i'm not entirely sure it will fit as my GTX3076 only clears by a few mm. (the GT35 has a larger compressor housing) You would probably need to buy a Tial stainless vband rear housing and get it hacked up due to space constraints, and mount the wastegate off that. PM me for more info.
Hi All,
Just letting you know that this GB closes tomorrow.
This is the list so far of people that have said they have paid:
Commsman
LineItUp
R6n350GT
rosella
dcdc
Howaitonaito
Rudi_ARX-TURBO
Ot1
Mr 20Valve
Skip_o_Valov
joshm35
WAGON_BOY
bigkevracer
ironpaw
impul535w
scotty nm35
Sydsyd
Daleo
Jetwreck
Prince Skyline
If you have paid and your not on the list let me know.
cheers
Craig
Nate, where are you getting yours sent?
There's at least 2 guys on the list above from Brisbane (Joshm35 & dcdc), you're at the Goldy & I'm not that far further south.
I'm OK with mine going to one of the Brissy guys. I can get it from there & drop yours off. Or if you are in more of a hurry, I'll get mine from you at Robina :)
Craig, is 4 bars enough to do a combined post to Qld?
just transferred today, might arrive tomorrow or the day after, depends on each bank's transfer protocols.
pls let me know if you haven't get it by Thursday, there's always a stupid chance of the money bounced back.
Yeah id be happy to get mine from robina..
I'm in Brisbane too!
That makes 3 then.
Sorry Josh, I'm voting you as the delivery point, lol. Makes sense if more of you are in Brisbane.
Either that or you all come down here for a vist...
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
