Gcg or any turbo company, should b looking at how to adapt the factory housing on the gtx series as they would make a truck load of cash, basically bringing out a hole new line up for gtr low mounts around the world.... Not everyone what's a big dirty cheater single.....
We can already have the stock GTR comp covers machined to fit the GTX2863R.
The problem is they surge ported the GTX covers for a reason. We don't want to 'try it out' in case its a flop and we certainly don't want to spend someone elses money to see.
To answer the question above. Yes the comparisn from -5 to GTX on Tomei manifolds would be enough also
  • Replies 70
I dont no man, there's a lot of people in this world that have gtr's and low mount twins. They are losing sales because it's a pain in the ass to fit the gtx turbos. So why not design a new cover for em so they can b adapted, could surely couldn't cost that much, I mean they make turbos all day everyday, something like making a housing to fit should b that hard. They have made them all before. I'm guessing, but surely you wouldn't think it was a big deal considering that's what they do....
Wouldn't the bigger inlet and outlet be a major player in the figures, therefore, even if a surge ported cover with 2 bolt outlets could be achieved, it's restricting the gtx design and why it works so well.. Would make it a different turbo altogether. Be hardly worth it to produce a mediocre result from what can be achieved with the original gtx design?
Not really. They are surge ported to allow air to pass on to the exducer faster. It will allow more flow that way but we could back cut the comp cover to achieve a similar result I think.
The GTX turbo bolts straight inside the turbine housing of a -5/7/9 so if you want your comp cover machined up to suit I can get it done for you no problem.
They will be cheap for whoever wants to trial them that way. I'm talking around $1k a piece but that still hasn't been confirmed yet. STILL waiting for return phone calls on it. Hopefully I can chase it up a little more tomorrow
Daniel can you get supertech valve springs at a good price also? might aswell change them also in case the tomei's are a restriction.
Absolutely. Can I sell them to you at a good price though? Hahaha
*looks around to make sure Nismoid isn't watching*
Damn that's a good price Dan.
What price? I don't know what you're talking about.
sorry for the ignorant question but the GT-RSs have a slot in the comp cover, is that a surge port? and ifso would the GT-RSs comp cover go onto the GTX?
I don't think it would make a difference man. The GTX have a much bigger inlet to the comp wheel than the "GTR friendly" turbos.
The GTX low mounts simply just aren't bolt on :(.
i ready to go i have emails elite racing with all my detail and im ready for anything they want to try i have a shit load of stuff to build the head also if you want a built head and a spare block :P let get the 34 started new project and sponsorship come on guys lets do it for my amazing fiance that has cancer it is her and my dream car lets do it
Hi elite racing iv been trying to contact you about this project if pickups please get back to me today as im about to buy a new step zero stroker kit to build responsive motor please et me know as I dont buy it if im doing this as that stroker kit the say dont push it past 405kw to be safe thanks again guys im willing to get my spare motor shit buy you guys if you want to build it to what ever spec you want thanks again
Hi mate I got your email. I'm not ignoring you but I'm currently booked out until September 5th so getting in to reply is something difficult to do (especially because I don't want to give you a 1 line reply)
You being local is a bonus for test fitups so I'm organising a pair to be sent to me for a test fit if you are willing
Are the manifolds on the engine at the moment?
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
