I think your WHP are overinflated American specs. I'm running a shitload of massive upgrades and an UpRev tune and i'm only running 230WHP.
Agreed. I have all intake/exhaust mods and spacer (tune could be better was slightly lean) and made 165rwkw. This equates to around 220rwhp.
200rwkw
5AT - HKS turbo kit, 6psi, uprev. I've seen uprev tunes from US cars making over 300rwkw, with not a lot of difference to my tune, but with a bit more boost. What I've figured is that the yanks over exaggerate their figures.
It all comes down to the dyno operator and what your paying them to do. Example- if you paid me $1000 to fit the new beut part to your car and tune it, you would like to see a increase in power yeah? dial up the dyno.... its that easy.
Do you think a NA "200kw" car has the same power as my 200kw turbo'd VQ35?
200rwkw
If the NA had 200wkw and you had 200wkw on the same dyno, then yes you'd have the same power. :P
(yes mate, I know what you are saying)
Torque would be fairly different though
You always hear about the plenum spacer mod, but I never hear anything about the runner spacer or throttle body spacer. would either of these be helpful in an N/A setup?
Runner spacer will increase low-mid rpm torque a bit. Just as it does on an M35 Stagea.
pv35gt8 has one on his V35, but it is difficult to feel much difference due to the CVT.
At the expense of a little top end power usually. Unfortunately the peak power figures can give a false sense of power gains as they are only up high in the revs where they don't get used much. More torque in the midrange is what people should be chasing imo.
The mentioned runner spacer was made out of the same phenolic material as the spacers for the VQ25's, and can not be used in conjunction with the plenum spacer. (not the 17mm spacer that I made, could be possible with the more common 8mm spacers that everyone else has installed.)
Once I put the Cosworth plenum on it will be available if anyone wants to give it a try. I will be able to package it as a kit with all the required bolts, spacers and gasket.
Edited by pv35gt8
Are you an uprev pro dealer?
And please explain why uprev cannot go over 375whp.
or did you copy and paste this from My350z?
I think he's referring the the VQ35DE engine revision, not the ECU flash/tune....
http://en.wikipedia.org/wiki/Nissan_350Z#Models
is this just a bonnet clearance issue?
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
