I love the agressive look, gonna buy em and drive till i get defected :(
That REALLY is not a very smart idea! Its like waving a red flag at a bull!
Like the other guys have said, as soon as they spot the over-sized wheels on the car, it is an invite to go all through the vehicle, and you have the potential to have all sorts of things defected... including not having enough water in you windscreen wiper reseviour.
Could become bullshit expensive, and time consuming, and for what? having some Mexican poke?
Haha so true mate, that wasn't a very well thought out comment
I'm gonna carefully consider offsets/sizes before i buy.
most likely 9.5's all round with +15 at the rear and +22 at the front.
I would probably kamehameha the cop if he pinned me for my windscreen wiper reservoir :/
Is that offset going in a GTR? They will still poke out on a GTST. I had 17x10 +18 on the rear.
naaa, going on a 34gt. +22 is pretty flush for the fronts from what ive heard, concerned about the +15 for the rear.
oh well, I've bought the wheels, just awaiting postage, i'll post up pics when they are fitted.
I've got 17x9.75 +25 with stretched tyres on my r32 gtst, stick out a bit.. Had them on for 6months now and been passed hundreds of cops only been pulled up twice and never had any probs with the wheels at all.
That doesnt stick out anywhere near as much as this guys 10 +15 will
Another thing to keep in mind that the cop asked me about was what size are the standard rims and what amaze rims are on the car. Lucky they were only 1 inch bigger so he couldn't get me for that either.
Hmmm, I was going to run 18x10" +22 on my GTT, But bit worried they will stick out to far. Opinions ?
Yeh, mate,, you're gonna have the same problem as me, I'll pm you a few posts ive found of guys that have done +22?
it's too late, i've already ordered the rims, so i'll post up pictures soon, when they are delivered and fitted.
I think the gt's are 16" so i should be right i think, cos i think the limit is 2" from memory.
will stick out by about 25mm, meaning you'd need stupid camber, massive stretch or a decent flare to have a chance. the picture ive attached is a 9.5 +20 running around 1.7 degrees camber. making anything bigger fit would take time and money.
what tyre size are you running?
my 275's with shitty +48 offset stuck waaay out on my supra(and i had a widebody!)
Got pulled over by the cops 3 times for various things , not one said anything about the wheels , and it had a fair bit of poke to....
in saying that....i don't advise doing that as its not worth knowing your riding on a defect every time you sit behind the wheel and as with all defects its up to the discretion of the cop.
also , flush looks awesome :)
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
