Im still waiting for the following to arrive, Tomei stud caps, Tomei 1.5mm oil restrictor, ATI 1000hp balancer and a few other bits and pieces that i have forgotten. After countless delays and f**k ups im pleased that my build has picked up speed it seems like my goal of having the car back on the road at the end of the year is still in achievable.
Edited by Tyranus
Nice one Sedat. It is pleasing to hear that things are moving. There is nothing more frustrating than waiting for things to be done.
btw - what is the flow rate of that Nitto Oil Pump? Must a be a fair bit if it comes with a head oil drain.
Cheers Anth, the only flow rate figures i could find was 64.8 @ 7k rpm. I'll need to ask my engine builder to get 100% correct answer. The head oil drain was actually an add-on that i got. My engine builder suggested that i should have a oil return line from the back of the head going to the sump so i dont have any oiling issues when im revving the engine over 9k rpm.
Edited by Tyranus
Hey Sedat you probably are already aware of this not sure if it's stated in the info that comes with the pump but the Nitto pumps runs dual springs and you need to remove one otherwise your oil pressure will be around 140 psi. PM a member on her named Shazz as he just had to remove his engine to fix that problem.
  • Like 2
  • 1 month later...
Update:
Ive purchased a Nitto 1.1mm oil restrictor
ATI 1000HP Balancer
Tomei Cam Caps/Covers i think thats what they were called
The major update:
The block is back at the workshop and is being put back together :D :D :D
The block has had its final spray (gloss black) and will be assembled this week!
And some comparison shots of rods for a 2JZ (Carrillo rod)(3.4 stroker build), RB30 (Nitto rod) and mine RB26 (Nitto rod).
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
