ok just noticed last night that when I go to reverse, my wing mirrors wont dip anymore. All functionality are working fine
it just wont dip. Is there a switch located on the auto lever hiding somewhere? and how to remove the plate to have a look? Is this a common fault on a stageas?
There is a little button down near you "right knee" little round push button. Thats where it is on mine. Hope this helps
God I felt like a dumb ass!! :unsure: I tried the button and wing mirrors back to normal again, I must have knocked it when I was wiring up my front doors
for courtesy lights. Thank you Josh. ;)
  • 1 month later...
i didnt know i had it untill i got my first service done when they done a computer diagnostic check and they dipped after that but they stopped working again after a week or so.
so its handy to know there is a button to turn them on and off :)
Do yours work ok?
With mine when you put it back in drive they move up a tiny bit more than they move down so after a couple of times they're way off. So I just leave them off
That happens with mine as well, although more so with the passenger mirror. I've just got used to every so often flicking the mirror joystick to lower it.
Along with the auto dipping function on mine the mirrors also automatically fold in when I lock the car and unfold when I start the motor.
What I don't understand is why they don't install the auto switch near the power mirror controls, then the button would make more sense to people. Still, it is exciting discovering extra features later on.
There are aftermarket devices that can easily be fitted to any car with power mirrors such as this one from http://www.LaneFX.com/ . The settings on this one can be adjusted and it has other features such as blind spot cover when changing lanes. I was planning on fitting this to my R31 but first I have to install power mirrors to the "pov pack".
Edited by QJQ
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
