Body just a bit off on the breathing/hold timing and bingo it's lights out. On top of getting light headed , I used to get an occasional blood nose when I was doing heavy stuff back in the day but, apparently it's normal. Or at least I was told it's ok?
A mate of mine likes to do sumo; has recommended it often to me. He says it feels more autonomous to him; he doesn't have to think about his technique as much to do the lift correctly/safely. Still doesn't lift as much as me though :P
Well I gave Sumo a shot today to see if it pisses off my lower back like regular deadlifts always manage to...nope, absolutely no pain at all. It removes a lot of load from the lower back and send to hand it off to your legs lol. Managed to do better today than the last time I did regular deads.
Will definitely be doing Sumo deadlifts from now on, though I'll still get to sorting out WTF is wrong with my regular deadlift.
Its strange how many think sumos are easier than conventional.
The biggest deadlifts in history are all conventional
Benedikt Magnusson, Andy Bolton both over 1000lbs, Konstantinov, Koklyaev over 900lbs, even here in Oz Odell Manuel 400kg, George McLaren 375kg.
There is no doubt though that some are more suited to sumo. Here in the gym we have 2 guys pull 300kg conventional, Martin should be next and he has switched to sumo, Dan has 290kg conventional and Roger has pulled 300kg but not in a comp, he too is conventional
Wasn't Martins choice. His deadlift had stalled and Max decided to try sumo. Max also noticed that Martin had stopped front squatting.
Up until Nats, Martin trained himself, he went into Nats with the 2nd highest total at PTC, came out with the 7th highest, all those in front had been trained by Max, so he asked Max to train him.
His results will be skewed by the fact he has added bodyweight, so were not going to sit here and make outlandish claims BUT he went into Nats with a 685kg total and went 687.5kg in the same weight class.
First thing Max did was to get Martin front squatting again and to have a program for him. I think Martin will go close to 730kg at ProRawFive.
The reason Max switched his deadlift was to take advantage of his levers, Marty has long arms
He is currently the only PTC lifter doing Sumo
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
