Body just a bit off on the breathing/hold timing and bingo it's lights out. On top of getting light headed , I used to get an occasional blood nose when I was doing heavy stuff back in the day but, apparently it's normal. Or at least I was told it's ok?
A mate of mine likes to do sumo; has recommended it often to me. He says it feels more autonomous to him; he doesn't have to think about his technique as much to do the lift correctly/safely. Still doesn't lift as much as me though :P
Well I gave Sumo a shot today to see if it pisses off my lower back like regular deadlifts always manage to...nope, absolutely no pain at all. It removes a lot of load from the lower back and send to hand it off to your legs lol. Managed to do better today than the last time I did regular deads.
Will definitely be doing Sumo deadlifts from now on, though I'll still get to sorting out WTF is wrong with my regular deadlift.
Its strange how many think sumos are easier than conventional.
The biggest deadlifts in history are all conventional
Benedikt Magnusson, Andy Bolton both over 1000lbs, Konstantinov, Koklyaev over 900lbs, even here in Oz Odell Manuel 400kg, George McLaren 375kg.
There is no doubt though that some are more suited to sumo. Here in the gym we have 2 guys pull 300kg conventional, Martin should be next and he has switched to sumo, Dan has 290kg conventional and Roger has pulled 300kg but not in a comp, he too is conventional
Wasn't Martins choice. His deadlift had stalled and Max decided to try sumo. Max also noticed that Martin had stopped front squatting.
Up until Nats, Martin trained himself, he went into Nats with the 2nd highest total at PTC, came out with the 7th highest, all those in front had been trained by Max, so he asked Max to train him.
His results will be skewed by the fact he has added bodyweight, so were not going to sit here and make outlandish claims BUT he went into Nats with a 685kg total and went 687.5kg in the same weight class.
First thing Max did was to get Martin front squatting again and to have a program for him. I think Martin will go close to 730kg at ProRawFive.
The reason Max switched his deadlift was to take advantage of his levers, Marty has long arms
He is currently the only PTC lifter doing Sumo
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
