If you depend on it, it's a crutch. I'm not saying they don't work or serve their purpose, but once you start don't expect to stop.
Will probably do it myself one day, but prefer to hold off as long as I can.
See I dont think it is necessarily a crutch...
And thats why im seeing what everyone elses opinions are.
Imo a belt just allows you to apply more pressure when creating the internal 'belt' using your stomach.
If it allows you to squat 10kg more, thats your quads, thorasic, CNS, etc. all getting used/havin to that 10kg heavier load, yet you're still applying the same pressure, if not more, due to resistance of the belt.
  • Like 1
If you look at the strongest deadlifters in the world, they all wear belts during training and competitions, and I don't think they have weak backs! There is a strong (haha) correlation between those who wear belts and those who lift crazy heavy weights.
My thoughts essentially echo jangles.
And if you plan on competing, you may as well train with the gear you're going to use.
Im think im gonns start using the belt more once my back gets better and I can start squats and deads again.
Super bummed because I finally hit a 160kg squat and a 210kg dead and then did something to my back bending down to get something from the fridge :(
What sort of belt to you use?
Unfortunately, it's usually the straw that breaks the camels back.
need to work on my deadlift form. No pain from the lift but an experienced coach has pointed out a couple of flaws in my technique that he recommends me fix before comp day. Hopefully it helps me lift more.
not sure if link will work or if my FB account is on private or not.
https://www.facebook.com/video.php?v=10153230373749688&set=vb.598394687&type=2&theater&notif_t=video_comment
I find a belt a must for heavy squats. That said I squatted 180kg @ 88kg before I started using one.
I never used a belt for deads as I could never get comfortable. Until I realised I needed to loosen it and wear it much higher than when squatting. I now wear it around my upper abs/mid back, rather than down around my lower back.
If you can set your lats tight and fight the rounding of your mid back you can transfer more of that initial leg drive to the bar. That's where a belt can help. Once you lose tightness in your mid back all the load get's transferred to your lower back and you will have trouble at the top locking the weight out.
I don't see a belt as a protective device. Plenty of people have hurt themselves wearing one. They're just an aid to keep tight and not let an power leak out during a lift.
  • Like 1
Congrats on the squat nick
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
    • Yep, cheapest options, neglected and abused. The fastest way to dislike a car is to get assigned that model by a budget rental company
    • The noise complaint could be from absolutely anywhere, and anyone. Get it actually noise level tested to find out if you're actually over, or if you're fine. If you're over, quieten it down. If you're under, carry the test results in the car with you.
    • SAU NSW x Benzin Cafe Cars & Coffee Sunday 12th October 2025 7:30AM Meeting Benzin Cafe Meet Location: Benzin Cafe Dural RSVP: https://forms.gle/Q9TcFu9DHe4dbvtKA   *Disclaimer* One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
