Hi All,
I was bored on the weekend (actually let's say feeling productive), and I recently acquired this cheap amp for $20 and needed to mount it somewhere out of the way. Instead of mounting it under the seat like some, I decided to make use of the space between the fuel pump access point and the HICAS crap.
Note: This only applies to R33 Coupes.
I reused the stock fuse block bolt holes, one thing to notice, there's a tab on the rear side of the block that needs to be trimmed/snapped off in order to allow the plate to sit flush.
Other than that, the photos should speak a thousand words.
Final note, I've previously found that mounting the amp there, next to all the power lines, etc. 'may' cause some noise, but when I replaced it with better RCAs the noise went away. In the past, I've used 2x Z like alloy brackets I made using a flat piece of alloy. Too much drilling involved, this method requires you to only drill 1 or 2 holes. I went for 2x because of that odd looking bracket I found.
Nice work, do you have the dimensions for the amp? The Kenwood amp I had in my last r33 would not fit in there.
Edit: found the amp at the Kenwood site Size [mm] : 330[W] x 59[H] x 227.26[D]
Edited by pfcr33
Are you sure?
It does the job for giving a bit of extra sub bass. Given that the car has enough road noise despite sound deadening in doors and under the rear seat/wheel arches you have to accept the car is flawed for getting great sound.
This is good enough for my needs but clearly not perfect or ideal.
his rear speaker cones still seem to be intact
How can you tell from that photo unless it was shot clear the fark out you wouldnt know ?
they will without any doubt distort when turned up and eventually blow the cone past the voice coil gap by the air pressure firing into the underside In turn it frys the speaker , sometimes instant sometimes slow death depnding on the pressure wave , they do make soft foam inserts to stop it or you can make some easy enough
Ive been doing this since before your birth prob so dont bother with your theory rants Mate
I'm sure if his speakers were blown he would know and that he would have noted that too.
That's great you've been doing since my birth.
Your such a muppet "wanna be smart ass" good to know your the audio "GOD " I'd better stop posting cause you know it all !!! let me bow down to you
Why bother being informative to anyone like you ? Disrespectful ass
when did I say I was a god? when I have I recommended anything to anyone?
cool story
you're my hero man
so quick to tell everyone how long you have been doing this
every thread you have posted in that I have seen you get aggro
cawk
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
