Ev's - R32 Gtr - Targa/sprint/hill Climb Build
Yeah I had my eye on the car for a while, with so many cars on the market it was hard to decide which one to buy. Now I have it I think it was a reasonable choice. The old owner gave me a spare engine block so I gave this to Racepace which I will get them to build to their spec.
Hi All,
I have been thinking about the cage and seats and belts and how I may be able to get the car on the road for ease of getting it to the track.....
This is probably old news to those in the know......but I have done a little research for Victoria and roll cages and registration in Victoria and found the following useful link:
If I read it right, a VASS can sign off on the cage as conforming as long as you can check all the boxes listed. It seems seats and seat belts can be replaced with the racing items as long as they meet the checklist requirements such as the tubes they are secured to being strong enough to support the loads they may see in an accident...
First link - look at section 9.5, it has a paragraph referring to rollcages. It then refers you to the VASS checklist for modifications.
http://www.vicroads....torvehicles.pdf
Page 51 refers to roll cages and is the VASS checklist.
http://www.infrastru...1Jan2011_v2.pdf
SO, that said I wonder if when this build is finished if a trip to my local VASS Engineer will see the car able to be registered again?? Has anyone tried this before????
TL;DR version.
You need to think all the other modification going on is not just related to the cage. Just get a rally rego/permit like everyone else. Full rego = not going to happen. If it does, you'll only end up seeing greif from Police who don't know better anyway. And then there is the EPA - exhaust noise over 90dB and all that other shit means you are f**ked before you start, even a Racepace 4" exhaust doesn't come under and it took a LOT of arse ache for us to get my 3.5" passed (back when Ben ran the shop, not Chris).
TL version:
You should be talking to a VASS signatory first, they always look at it in better light rather than you doing it as an after thought. :)
Anyway VSI8 is very vague and has never been detailed in purpose and tells you to look at VSB14 and the LK8-10 codes. And the problem with VSB 14?
Is the sections in bold:
Users of VSB 14 need to be aware that this document needs to be used in conjunction with the appropriate administrative requirements of the jurisdiction in which they wish to either register a vehicle or to obtain approval for a modification for an already registered vehicle. Administrative requirements include, amongst other things, processes for vehicle registration, obtaining exemptions, obtaining modification approvals, vehicle inspections, preparation and submission of reports and the payment of appropriate fees and charges. If unsure of any of the requirements specified in VSB 14, or if more information is needed for any other issues concerning the administrative requirements, users should contact their relevant Registration Authority prior to commencing any work.
Basically VicRoads and the DIT point fingers at each other :)
VicRoads most certainly do have their own rules surrounding cages. I cannot think for the life of me what document it is in, I do remember having read it (along with a kunt load of other stuff over the years). However I know there were some changes about 18 months ago so perhaps with that the document has been pulled.
Call up VicRoads. They have dedicated engineers that you can speak to and they will then be able to go into further detail, I've done it before. But as i said earlier the EPA stuff is what is going to bring you unstuck here on every corner. Full Emission testing will be required, and forget that, more cost than it's worth for the sake of over priced registration.
If you still think you want to go through with it after talking to a VicRoads engineer - For a VASS i would highly reccommend Enkelman in Braeside. I've used them before as have other mates for some fairly modified cars. We knew the rules prior so modified accordingly and passed our inspections very easily. However none involved cages, but they are upfront guys and the better priced VASS signatories in Vic (some places will charge you really heavily for no valid reason).
Also totally unrelated.
What are you doing for suspension?
Going Racepace Tiens or all out with MCA?
Thanks for the detailed reply on the cage/rego. I think I will take your advice and stick with rally rego and then club permit in 2014. It makes sense now I think about the total picture.
The car currently has bilstein shocks on it (adjust comp and rebound & height). Chris said they were ok for now. I would probably go with the Teins for the next upgrade but am open to suggestion. whats the difference with MCA versus the RPM Tiens? I need to purchase and fit some adjustable arms for the front etc. It has adjustable camber arms on the rear already.
cheers.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
