Sau Vic 2012 Motorsport Championship Round 7 - Hh 13Th Oct
  • Replies 111
Posted Images
Been waiting all year for this :)
just got to get the civic ready
Reverse figure 8, is the track ran backwards? or you go straight instead of turning left and going down the dipper? have only ran it clockwise
Edited by xris
ok so im about to enter, only thing im confused about, i know asaa licence covers it, but, club member? as in wrx or skylines aus member? im asuming i need to pay the $95 as im a sau member? let me know about that and ill submit the forms, 2nd event! be interesting to see the differences over deca
Heads up to people thinking of heading out to hh (bryant park) next month wanting practice this month.
GCC has an event this sun (I'm thinking of entering depending upon weather) entries close tomorrow 5.30pm.
http://www.gippslandcarclub.com.au/suppregs.html
Only 2 problems
1. If they get 100 cars, you really don't get many runs at all (where WRX is 80)
2. It's CAMS and not AASA, so anyone without CAMS it's extra $$
not what i wanted to hear martin! :yucky:
They are still better than cold high performance road tyre like a AD08 - so it's not a major concern.
It's more the brakes and having no heat in them on the reverse Fig 8 given after you launch you can have some fair speed going and need to jump on the anchors. Lots of time to be gained there if you know your braking setup performance from cold.
Only 2 problems
agreed but from what I ahve seen in the past they don;t get anywhere near that number.
meant to be a well run day as well.
we might be looking at doing some GCC rounds as part of our champ next year.
Heathcote timing never works, track condition depends on the moon.
Not worth driving up there for it. Better off going to Calder on a proper track with timing even though it costs more and you get less runs
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
