  • Replies 46
How much fun I had:
Words cannot describe how much fun I had. I was very very excited leading upto it and it by far exceeded all my expectations.
What I learned:
1. HOW TO TAKE TURN 1!!! - That was a very big off but I am glad that I got them all out of my system @ the first trackday so now I know what not to do. I'm disappointed that I did it so close to Steve Bullin but it was great that Daz, Carlo and Steve were all very supportive of me :P
2. WINDOWS UP!!!!! - everyone saw my interior
3. Duncan is a champion!!! (more than he was before :P) without him I wouldn't have learned as much as I did
What I need to work on:
Braking & heel-toeing. Although by the end of the day I was using the ABS less, I was using it alot coming into the horseshoe and turn 10. I was also compression locking into 2nd alot too..
Better tyres and suspension setup will fix this. You will probably find that your front end is too stiff or too low.
How much fun I had:
What I learned:
1. HOW TO TAKE TURN 1!!! - That was a very big off but I am glad that I got them all out of my system @ the first trackday so now I know what not to do. I'm disappointed that I did it so close to Steve Bullin but it was great that Daz, Carlo and Steve were all very supportive of me :(
3. Duncan is a champion!!! (more than he was before :D) without him I wouldn't have learned as much as I did
:P
Its funny, my experience was almost identical Tosh. Turn 1 looks ominous and seeing the speeds that some of the GTR's approach it made me somewhat nervous but after a couple of laps you get the feel for it and begin improve your line/speed.
1 big off that I had was unfortunately also with the window down and my interior was caked in brown dust.
I would have liked to have had duncan passengering for a few laps but the car wasnt behaving well at all so I called it a day.
Looking forward to the next one :(
hahaha what is it about turn 1 and MR2s spinning :(
actually I did a few laps in tush's MR2 and I was very impressed, its got great turn in, and traction out of corners. - you do have to be careful under brakes but it was certainly not the super spin-ey car that some people claim.
Shame that Ben kept chopping us on the straight tho :)
Welcome to Team Trackday guys ;)
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
