  • Replies 40
mofos at tirerack won't ship yoko's or hankooks. Dunlop it is!
The last quote I got for the Dunlop Direzza Z1 Star specs in Australia was between $360 and $400 a tyre if I remember correctly.
Tire rack had them at the time for $128 a tyre.
Add the $350 shipping and I was still miles ahead in savings.
Things may have changed though.
Not yet. It's $1185 landed from Tirerack for the set. Are they a much better tyre than say Federal RS-R's?
I believe the Federals are a UTQG 140 where as the Dunlops are 200, Ive never used Federals myself so I cannot compare.
The Hankooks are 140 and I found the Hankooks wear more than the Dunlops but the Hankooks are more grippy straight off where the Dunlops needed a lap to come good and did get a bit "greasy" after about 8 laps at Wakie.
Disclaimer: Im far from a expert in these things.
Thats a bugger though about not shipping the Hankooks, I myself may go back to the Star Specs.
  • 3 weeks later...
the add mentioned above is listed by me
the ad08's are excellent and worth every cent
was running these on my 300kw+ r32 gtr and the grip and handling exceptional
reason y i am not running them as i have gone to 355 disks and need to run 18's
Just ordered x4 Nitto NT555's in 255 40 17 for $125ea in free delivery. 3 hours left for the sale at time of writing. Not sure how good they are but should be OK for 2nd set of rims.
http://www.ozzytyres.com.au/store/nitto-255-40r17-94w-nt555.html
  • 3 months later...
ES501's are a "Comfort" "silent" type tyre for people who value things like fuel economy.
Toyo Proxes4 seem like more of a performance tyre so should be comparable to Fed595, possibly better. For $170 they seem like worth trying.
Do a search on here, you should find plenty of good info.
Proxes 4 are not a UHP tyre in the way that the KU36 and 595s are. They are a good tyre, but they are nowhere near as soft in the compound. They have a treadwear rating of 300 vs the <200 numbers on most of the other tyres being discussed. That puts them in the same company as the FK452 and so on.
I've used both the Proxes 4 and FK452 on my R32 many years ago and the KU36s were like chalk and cheese in terms of sheer grip. I used to get up to 20k km out of FK452. Only get about 10k km out of KU36. They are in a different world.
Dunno what the nitto invos are worth in a 17 but they are a great street tyre loads of grip and VERY quiet. If you did get 595's make sure you get the Z soft compound 1's think the tread wear is 220 cos the taxi spec hard compound 1's are crap!
I've used Toyo Proxes 4 and find them some what similar in performance to a cheaper Kumho KU31 (half the price of the Toyos).
Mick, I jelly it says you haz Evo 9 :)
Haha yeah Johnny its such a blast to drive! Not near as quick as my 33 BUT I'm working on that :) the evo has Dunlop SP maxx tyres on it and they are quite a good tyre I've found. Bit noisier than the invos but they are quite good in the wet and the dry.
I've driven a few of EVOs my mates own.. they're fun to drive, but you do miss the fighting nature of the car (that being an uncontrollable RWD) :)
You'll probably leave SAU and only be on OzEvo all day long
Yeah i will see how the evo feels when i wind it up to 300+kw like i did with the skyline lol :woot:
But no never the SAU community is far better than the evo crowd :whistling:
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
