hey,
will i finally got around to removing my side door nismo sticker, and after removing the first letter, i found out that the sticker had been clear coated :( So after removing the whole sticker, i can still see the NISMO up close :D
Does anyone have any idea how i can remove it or what to do thanks?
mike
Or try straight eucalyptus oil on a cotton ball and rub the residue off. You can buy it from coles or woolies in the mecidinal section. Also good for mozzie bites. It gets rid of the sticky residue or paper residue left behind by stickers. I have never used it on a car body, but its been fine on glass, walls, cupboards etc.
I wouldnt bother trying to fix it. I had a blitz access ecu sticker on my bonnet when it came into the country. After spending 6 hours picking it off (it had been baked on by the sun), i realised that it had taken the layer of clear coat off the top of the paintwork. I highly doubt a buff will fix this, ive tried everything with not even a slight reduction.
Dont think its been clearcoated onto the paint, but it being there for so long has caused it to come off with the sticker. On mine you can actually feel that the area where the sticker was on is lower than the rest of the paintwork! badness!
:D
Red17
Are you 100% it has taken the clearcoat off mike? stickers have a tendancy to leave adhesive on the door that looks similar to that, a bit of prepsol would remove it.
I doubt they would have clearcoated over the sticker, and if they had, the sticker would have been damn near impossible to remove.
I could be wrong, but you should try some prepsol to remove residue, then a nice cut and polish to bring it back up.
memphis, im guessing its clearcoat :s , thats why i post the photo. when i remove it like clear stuff come off with the sticker.
To get it off i use hairdrier, after the sticker came off there was white stuff left behide, which i guess was glue so i use methylated spirits to remove that, but like i said above clear stuff came off with the sticker and i can also pick at it
I guess they must have put a very fine coat over it, grab some cut n polish and see how that goes.
Normally adhesive on the sticker is clear...
make sure you get stuff thats clearcoat safe, you may need to get some 2000 wet n dry and cut back the clear a bit, then polish it. If you dont feel safe doing this a detailer can do it, but they charge alot.
thanks memphis :P
if u know any good detailers, u can recommend can u plz pm me them details (also if its in the magla that would be good)
also i have notice that when i feel the area the area which has the nismo is lower compair to the rest of the door (if u get me)
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
