hey,
will i finally got around to removing my side door nismo sticker, and after removing the first letter, i found out that the sticker had been clear coated :( So after removing the whole sticker, i can still see the NISMO up close :D
Does anyone have any idea how i can remove it or what to do thanks?
mike
Or try straight eucalyptus oil on a cotton ball and rub the residue off. You can buy it from coles or woolies in the mecidinal section. Also good for mozzie bites. It gets rid of the sticky residue or paper residue left behind by stickers. I have never used it on a car body, but its been fine on glass, walls, cupboards etc.
I wouldnt bother trying to fix it. I had a blitz access ecu sticker on my bonnet when it came into the country. After spending 6 hours picking it off (it had been baked on by the sun), i realised that it had taken the layer of clear coat off the top of the paintwork. I highly doubt a buff will fix this, ive tried everything with not even a slight reduction.
Dont think its been clearcoated onto the paint, but it being there for so long has caused it to come off with the sticker. On mine you can actually feel that the area where the sticker was on is lower than the rest of the paintwork! badness!
:D
Red17
Are you 100% it has taken the clearcoat off mike? stickers have a tendancy to leave adhesive on the door that looks similar to that, a bit of prepsol would remove it.
I doubt they would have clearcoated over the sticker, and if they had, the sticker would have been damn near impossible to remove.
I could be wrong, but you should try some prepsol to remove residue, then a nice cut and polish to bring it back up.
memphis, im guessing its clearcoat :s , thats why i post the photo. when i remove it like clear stuff come off with the sticker.
To get it off i use hairdrier, after the sticker came off there was white stuff left behide, which i guess was glue so i use methylated spirits to remove that, but like i said above clear stuff came off with the sticker and i can also pick at it
I guess they must have put a very fine coat over it, grab some cut n polish and see how that goes.
Normally adhesive on the sticker is clear...
make sure you get stuff thats clearcoat safe, you may need to get some 2000 wet n dry and cut back the clear a bit, then polish it. If you dont feel safe doing this a detailer can do it, but they charge alot.
thanks memphis :P
if u know any good detailers, u can recommend can u plz pm me them details (also if its in the magla that would be good)
also i have notice that when i feel the area the area which has the nismo is lower compair to the rest of the door (if u get me)
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
