hey,
will i finally got around to removing my side door nismo sticker, and after removing the first letter, i found out that the sticker had been clear coated :( So after removing the whole sticker, i can still see the NISMO up close :D
Does anyone have any idea how i can remove it or what to do thanks?
mike
Or try straight eucalyptus oil on a cotton ball and rub the residue off. You can buy it from coles or woolies in the mecidinal section. Also good for mozzie bites. It gets rid of the sticky residue or paper residue left behind by stickers. I have never used it on a car body, but its been fine on glass, walls, cupboards etc.
I wouldnt bother trying to fix it. I had a blitz access ecu sticker on my bonnet when it came into the country. After spending 6 hours picking it off (it had been baked on by the sun), i realised that it had taken the layer of clear coat off the top of the paintwork. I highly doubt a buff will fix this, ive tried everything with not even a slight reduction.
Dont think its been clearcoated onto the paint, but it being there for so long has caused it to come off with the sticker. On mine you can actually feel that the area where the sticker was on is lower than the rest of the paintwork! badness!
:D
Red17
Are you 100% it has taken the clearcoat off mike? stickers have a tendancy to leave adhesive on the door that looks similar to that, a bit of prepsol would remove it.
I doubt they would have clearcoated over the sticker, and if they had, the sticker would have been damn near impossible to remove.
I could be wrong, but you should try some prepsol to remove residue, then a nice cut and polish to bring it back up.
memphis, im guessing its clearcoat :s , thats why i post the photo. when i remove it like clear stuff come off with the sticker.
To get it off i use hairdrier, after the sticker came off there was white stuff left behide, which i guess was glue so i use methylated spirits to remove that, but like i said above clear stuff came off with the sticker and i can also pick at it
I guess they must have put a very fine coat over it, grab some cut n polish and see how that goes.
Normally adhesive on the sticker is clear...
make sure you get stuff thats clearcoat safe, you may need to get some 2000 wet n dry and cut back the clear a bit, then polish it. If you dont feel safe doing this a detailer can do it, but they charge alot.
thanks memphis :P
if u know any good detailers, u can recommend can u plz pm me them details (also if its in the magla that would be good)
also i have notice that when i feel the area the area which has the nismo is lower compair to the rest of the door (if u get me)
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
