91 r32 just came off the dyno
rb25det
t3/t04e
supporting fueling modifications
we are hitting a ceiling at 160rwkw at 5psi. ran up to 12psi and pulled all timing back and no change in power output
engine sounds fine on the headphones, air fuel ratios are safe, we have fuel for more power even at base pressure. turbo responds like a mid sized t3/t4 hybrid - positive pressure around 3000rpm, no weird noises
took a pressure reading from after the turbo, and also at the manifold - exactly the same power curve so we don't think it is a restriction in the intake/intercooler piping
airflow meter (z32) output voltage ramps up quickly with boost and then holds static voltage from there (with increasing rpm and boost).
the exhaust came with the car - I am thinking a collapsed muffler (baffles) or something??? it is 3.5" all the way through with one resonator and a rear super dragger muffler, but it is quite quiet
has anyone else run into similar issues before? could it be any other part of my system?
Given it's a 10min job to drop the exhaust and do a run, surprised you didn't to rule it out as an issue if you went to the effort of testing the pressure.
BUT... you tested the pressure, so you would know if it was a problem or not... So what were the results of that test? Was it overtly pressurised?
Either that or cam timing/belt is out a tooth. Seems fairly common that one.
while the problem was being diagnosed, the turbo oil feed line had a minor split and so we shut it down - didn't want to pull any power runs until we sorted that out since a major failure on the pressure side of the oil system would mean dead engine real quick.
we only took pressure values from the intake side, from the nipple right after the turbo compressor housing, and again at the inlet manifold. pressure readings were the same at both locations
I'm getting the oil line sorted shortly and just wanted to hear any opinions before I started down the road of figuring out this problem
we pulled the timing right back while trying to diagnose on the dyno with no change to the power output - surely if the belt was off we would have seen some changes there?
Edited by clip14
Cat has been removed - exhaust set up is as follows
factory exhaust manifold
38mm gate taken off the manifold before the turbo
custom downpipe with external gate plumbed back in
no cat
3.5" exhaust with one resonator and one rear muffler (installed prior to purchasing car).
Belt is for cam timing. You were adjusting ignition timing
no cat
I'd still be dropping the exhaust and doing a run/two to rule it out.
Very common for Jap exhausts to have 2.5" restrictors welded in before/after resonators/mufflers etc.
My rear super dragger muffler was all rusted and colapsed on the inside. They're a fairly old muffler I think. Ended up gutting it.
the muffler is not in great condition - will replace it this weekend. cheers
right, sorry about that. i had a chat with my tuner, he says he played around with the vct and it didnt look like there was a problem there. He will check the cam timing before it goes back onto the dyno.
will be dropping the entire exhaust and making sure it is alright - most likely will just get a new rear section rebuilt to be sure.
165 is also around the max a faulty cas makes, did the curve go wavy? look at exhaust first.
I dont have the output from the previous dyno runs on hand. what do you mean by wavy? which curve?
Is there any other way to troubleshoot a faulty CAS?
Thanks everyone for their responses!!
Edited by clip14
Meaning as it was on the dyno was the readout on the screen wavy? Going up and down as power rose. Or was it a smooth steady line?
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
