Wheel Repair In Sydney. Places? Recommendations? R34 Gtr Rims.
Hi All,
Looking for recommendations where to have wheel repair done in Sydney?
I would like to get my R34 GTR rims refinished in their factory colour as they have slight rash and stone chips on them.
I'm located in Rouse Hill so something local would be handy but willing to travel if necessary.
Done a bit of searching and found some recommendations but most threads I found of this nature are a few years old.
Appreciate any advice or direction.
Thanks.
Edited by iwanta34gtr
Or try Magman, he's located in Punchbowl, doesn't have a fancy website or anything but knows his schiz.
Address: 2/21 Moxon Road, Punchbowl NSW 2196 Phone: (02) 9709 2686
Not sure if magman does refinishing, but he does do straightening. Craved on this forum does refinishing (Craved Coatings). Many SAUers have used him and he does great work. But hes at Penrith.
I got my stockies powdercoated at craved, highly recommended
if you can't find an all in one place so to speak I used these guys to repair my gutter rash
http://www.mobilealloywheelrepairs.com.au/rims/wheel-rim-repair.html
then I got powdercoat at craved
Hmm im gona check out that place in Artarmon when i get my GTR back, i have a set for NUR spec Enkei NTOM-3 that appear to have a buckled rim or 2 that came with the car when i bought it.
  • 1 year later...
Gday everyone, bump to an old thread
Has anyone had any wheels repaired in Sydney of late? Seems like the guy i use in Botany has shut down, or he doesnt realise his phone is disconnected. Craved can paint them however not fix them.
Have had a bad experieance with wheel repair before which i wouldnt like to go through again. Looking to get some gutter rash repaired and the edge painted.
Cheers
Ian Raymond at Wheel Centre Repairs 43 Bay St Botany will be back from holiday mid-Jan.
Formerly Simmons Wheels, he's still my first choice, after I've used...
* Greg at MagMan of Punchbowl
* Nigel at OneStop of Unanderra
* Paul at OzWheels of Minchinbury
Daleo has a top recommendation too whom I can't recall right now.
  • 3 weeks later...
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
