  • Replies 3.5k
I love all sorts of genres all the way from Metalcore / Post-Hardcore up to things like Progressive House and Minimal Techno.
However didnt really think I would ever get into hip hop. Currently listeing to alot of East-Coast hip hop.
Loving alot of Wu-Tang Clan at the moment as well as the rapper 'Shyne'. Shynes first album, titled 'Shyne' is great if anyone into hip hop is after a good listen. Best songs in my opinion from the album are, 'Whatcha gonna do', 'Bad Boyz' and 'Bonnie and Shyne'.
Too many good Wu-Tang songs to recommend but my absolute favourites would have to be '4th Chamber', 'Da mystery of Chessboxin' and 'Careful (click, click)'!
Edited by Bennis
