I am having the same problem with boost spike. 18psi or 14psi actuators both shot up to 20-23psi everytime. Boost source from a weld on nipple after the turbo elbow. Intake leak tested OK. Tried just about everything. I am running a HG ATR43G3 internal gate. my concern was also around the wastegate hole/flapper. But since you're still having the same issue after porting etc, im lost.
  • Replies 66
Posted Images
The .82 type A/B turbine housings don't usually creep boost, How ever there has been a person reporting this issue, luckily he was local. What I've found is there is one stud hole that sits behind the wastegate flapper, the thickness of the material there is 10mm for oem stud, while 25mm bolt was used instead, So the extra length of the bolt pressed against the gate making it unable to move. That bolt is the one on top right corner if you are looking at it from behind.
our 14psi actuators holds 15psi on a free flow setup, and 17.5 with extended wastegate lever. The high pressure actuator holds 18psi and 21psi with extended lever. Most of our brand new turbochargers has extended levers, are fitted with a 14psi actuator.
With your 3076, I did not looking into your dump pipe, this is certainly a split dump pipe, as your turbine housing already had the wastegate divider built in, making it sealed in a chamber. While most internal gate would open to 45 degrees, the gate acts as a lid, trapping hot air inside the chamber causing boost creep. That also explains why a big 38mm internal gate would still boost spike on your setup.
Solution would be getting a bell mouth dump made, or mill out the wastegate divider on the turbine housing.
i'm sure the flapper was swinging out as far as it could, but i'll double check that, thanks. i've still got that 7psi actuator you gave me, i will see how it goes with that on aswell.
hey all, just an update.
I ended up getting a bell mouth 3 1/2" DP, figured i would try that before porting the gate.
It didnt completely solve the problem, but it did help.
It now only creeps 1.5 PSI, which is alot better.
Made 276 with max boost at 17 PSI :)
I also have this issue. I have an I/w .82 gt3076r. It always creeps to 21 + psi. I have the gcg split dump fitted. I believe this is the cause of the problem because although the waste gate appears to open enough because of the angle it partially blocks the wastegate pipe. I'm going to remove it and get another pipe made or this one modified. Ill let you know how I go.
  • 3 weeks later...
Theres No need for external gate, I'm just waiting for my new 3.5 inch bell mount dump to be made just seeing if others have had success, stao and Abe from havoc made a easy 330/340rwkw with internal wastegate currently mines at 324rwkw so I'll see how this dump goes once its made
True true fair enough then. I was thinking of future if and when you chase even more power (damn hp itch) externally gating will give you that opportunity now and I the future.
Here's a wee list of mind mate sorry bit log copied it from other post.
Thought I'd have a look and add my info car is currently on the build again bigger turbo and intercooler
But here is some figures when finally complete and
On Dyno will post sheets of new power.
Currently 427kw revs taken to 8800.
Cracked r34 gtt 25det neo
Fully forged from ground up.
Valves seats rings arp head bolts, studs
Wiseco forgiez
Tomei poncams stage 2
Rc 720cc injectors Greddy intake
Hypertune 90mm throttle body
4 inch intake piping all round
SARd external gate
Custome sinco top mount mani
ARE surge pot fuel pump wallbro x 2
Nismo engine mounts to stop torque bend ( still engine pulls hard lol)
Hks t04s 1.0 exhaust wheel (nice change at 4000rpm no valve noise means no cops lol)
Apexi avcr
Apexi el2 gauges oil pressure,temp water And boost
Apexi rsm
3 1/4 inch exhaust with cat back
Arc cold air intake box
Spitfire coilpacks
Upgrade vct module It's awesome keeping vct trust me
Basicly it there's heaps of other things but that's basic core stuff.
427kw atw at 1.4 bar boost
On Bp 98 ultimate
Oh and vipec ecu
Nice to see heaps of other tough 25 and 20dets reppin.
Are u trying to avoid the boost creep or are u chasing the 6kw?
GT3076R (52T), 0.82 A/R IW Garret rear, GCG split dump, 274rwkw (PULP) @19psi on Garret 1 BAR actuator
Full boost @3000rpm... No boost creep at all!
IMO the GCG split dump is a thing of beauty and works perfectly :thumbsup:
Yeh right, 19psi by 3k on a GT3076 with 0.82? Must be a 3L right? Most guys only hope to get that sort of response with a 0.63 rear, and no split dump is going to make that much difference.
EDIT:
I have a 3L, 9:1 Static CR, GT3076R with 0.82 rear and I make 14-15 PSI (1 Bar) by just under 3000 in 3rd/4th on PULP (BP 98).
19 PSI is in at about 3300RPM odd.
I guess its achievable but 19 psi in before or at 3000RPM. I wouldnt mind seeing a dyno plot to back it.
This is ofcourse unless its a stroker 3.2 or 3.4 lol
Edited by R32Abuser
I have not seen the results of a 52 trim GT3037/GT3076R on an RB30 so I'm not sure if or by how much the slightly smaller trim compressor affects spool/boost threshold . Me thinks a higher CR like 9.5+ would pull up a bit more low end torque pre boost and make it a little more linear with the boot in .
A .
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
