Hey mate
You got a Radiator overflow tank forsale
Is that the coolant reservoir bottle?
Cheers ben
pretty sure i have one floating around 20 bux plus postage, if you still need it flick me a pm
rear seats postage to toowoomba 4350 please. got any fronts without tears in them??
or even better any 33gtr seats
will get back to you with the quote shortly, only front seats i have are the ones in the first post
near impossible to get them without tears
  • Replies 148
Hey mate. Do you have the exhaust pipe clamp. Its the bracket that bolts to the gearbox and the cat with a small rubber insulator!?
What's the condition of the trans crossmember??
no exhaust clamp, crossmember is in good nick
hey fatz, i know yo have alot of $hit up there lol. Im after a throttle cable to suit forward facing plenum for my rb20. Wondering if you kept the one out of your last gtst you wrecked with that rb25. cheers
Console surround sold yet? if not how much to 3037
you mean stereo surround? I do have one but it has a small crack which is unnoticeable when mounted $45 posted
nah don't have one mate
Hey mate,
Still have the indicator stalk??
Is it all functioning?? (high beam??)
If so how much for delivery to 2906.
Cheers
Surprisingly they are all gone now
Sorry I have chucked about 10 of those out
Hey fatz,
Would you be willing to post the radiator to Wagga Wagga (2650) and if so how much?
oh and you don't happen to have an undamaged fan shroud to go along with that do you?
Thanks
-Vince
Hey fatz,
Thanks
-Vince
send us a pm will have to get a quote for the rad
dont have the shroud ( hard to fin not rooted)
Hey mate do you have a good Rb26 clutch fan hub? How much posted to Brisbane 4178
certainly do $50 bux posted
Wrecking Gunmetal Grey coloured R32 Gtr.
Heaps of parts, first in with the cash wins it.....
Rb26dett complete motor $2,500
Removed from a running 32 Gtr in Japan, driven by the buyer before wrecking.
Includes intake, exhaust, turbos, covers etc.
Doesn't include loom or ECU.
Stock ECU $150
Blitz dual stage boost controller kit $250
Speco tacho $60
Gearbox $500 incl shifter. Gearbox crossmember $50
Front mount intercooler (stock) $200
Stock radiator $150
G sensor $450 (not red)
Tailshaft $150
Stock clutch in very good condition $200
Driveshafts: sold
Diff $500
Rear cradle (bare) $100
Hubs $100 per hub, front includes uprights
Front lower control arms $80 pair
Front cradle (bare) $100
Front and rear sway bars $80 each
Front steering rack $150
Rear steering rack (incl rack ends) $150
Front calipers and rotors $250
Rear brakes- sold
Brake master $100 and booster $100
Exhaust manifolds $40
Dump pipes $40
Front pipe (stock) $100
Stock exhaust in excellent condition, includes heat shields (some of which look near new) and cat $450
Carbon canister $30
A/c compressor $100
Radiator overflow tank and washer bottles $20 each
Throttle cable $80
Bonnet release cable $50
Bonnet, grille and front guards: sold
Headlights $250
Bonnet liner/heat shield $30
Boot with Gtr wing and badge $250
Rear bar $100 (mounting brackets are a bit rusty)
Rear bar reo $200
Front window glass $200
Rear window glass $150
Quarter glass $50 a side but it has no seals
Doors $150 each
Side mirrors $30 each or $50 pair
Corner indicator, passenger side- has a hole in it $20
Tail lights $50 each
Front seats in good condition $500
Rear seats $150
Stock steering wheel (some wear) $150
Brand new Jap brand boss kit in box $30
Steering column (plastics, ignition barrel and indicator not included) $50
Indicator stalk $20
Steering wheel plastics $40
Speedo cluster $100
Triple gauge cluster $50
Climate control unit $30
Working clock $60
Interior carpet $70
Unbroken console surround $50
$10 bin:
-Footrest
-Interior roof light- centre
-Interior front map light
-Kick panels ($10 each)
-Boot plastic trim (bit around the lock striker)
-Door sill plastics (bit with Skyline written on it) ($10 each)
-Maroon passenger door handle
-White drivers door handle
-Various seat parts 10 bux a piece
There are stacks of other parts and trims I haven't yet listed, just ask. I'll be updating and adding new stuff as I get to taking photos and sorting it so check the last few posts for current lists of what's left and what's sold.
Pick up Valley Heights Sydney or happy to post most things, but not all.
Pete
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
