  • Replies 73
Tristan, starter motor still available, shoot us a PM
France, Injectors are still available and are top feed, low impedance, twin sprays.
Cheers
UPDATE
Oil filter housing - SOLD
Starter motor - SOLD
Power-FC - SOLD pending payment
Clutch - SOLD pending payment
Sard 800cc Injectors - SOLD pending payment
Inlet Plenum - SOLD
Rb26 Engine Block - SOLD
FR and RR turbo inlet snouts - SOLD
Idle Air Control Valve - SOLD
Inlet plenum sandwich plate - SOLD
Valley Cover - SOLD
Cam Covers - SOLD
Power Steering Pump - SOLD
A/C Compressor - SOLD
Stagea Mat - SOLD
Everything else is still up for grabs!
See something you're after, PM me an offer
UPDATE
Sard 800cc Injectors - Back on the market, price reduction
$520
R33 N1 RB26 Sump/front diff, Pristine condition with brand new Redline Lightweight Shockproof gear oil - price reduction
$370
Power-FC - SOLD
Clutch - SOLD
Twin Turbo Oil/Water hardpipes - SOLD
Inlet Plenum - SOLD
Valley Cover - SOLD
Cam Covers - SOLD
Stagea Mat - SOLD
ALL ITEMS REDUCED FOR QUICK SALE:
- High Mount Twin Turbo Kit.
$2000 $1800
- Upgraded R33 GTR Turbos.
$800 $750
- Sard 800cc twin spray injectors w/ injector clips/plugs to suit. Top feed, low impedance. To suit RB26DETT, fit in std fuel rail.
$550 $500
- R33 N1 Rb26 Front diff/Sump, 4.11 ratio, 8000km old, new Redline Lightweight Shockproof gear oil, perfect condition.
$500 $350
- R33 N1 RB26 Throttle bodies, 8000km old, untouched.
$300 $250
- R32/R33 S1 Coilpacks, full set, with mounting frame, 8000km old, P/N: 22433 60U02.
$250 $200
- R32/R33 S1 Coilpacks, full set, P/N: 22433 60U01.
$150 $130
- CAS with mounting bracket.
$200 $100
- R32/R33 S1 RB26/RB20 Ignitor x2.
$100 each $80 each
- R33 N1 dumps, with heat shields, 8000km old.
$100 each $100 for both or $60 each
- R33 N1 exh manifolds, with heat shields, no cracks, 8000km old, untouched ready for porting.
$50 each $70 for both
- Alternator with tensioner bracket.
$80 $70
- Throttle Position Sensor (TPS), 8000km old, perfect condition.
$50 $35
- Knock sensors, 8000km old.
$100 for the pair $50 for the pair or $35 each
- Knock sensor, oil press/temp and anciliaries loom.
$30 $20
- O2 sensors, titania, FR and RR, NTK.
- Assorted silicone heater/coolant hoses (new, never fitted) and used vaccuum hard pipes.
$80 $60 for the lot or offers for single items
- Water pump pulleys, 130mm and 140mm diameter.
$30 for both or $20 each $10 each
- Space Saver spare wheel, T125/90D16.
$30 $20
- Oil temp sensor.
$10 $7
- Thermostat housing/Coolant snout (block side) PLUS thermostat.
$50 $35
- FR and RR hotside compressor pipe/adaptor/snout, includes the rear OEM rubber hose.
$100 for the lot or $50 each $50 for both
- Coilpack loom, excellent condition, insulation still flexible.
$50 $35
- Air temp and coolant temp sensor.
$20 each $15 each
- Oil pressure sensor.
$20 $10
- Oil dipstick and tube.
$10 $5
- Oil pickup.
$30 $10
Hey mate, pictures of the turbs are found in the first post of this thread.
Full details are found on the first page, 3rd post from the bottom, of this thread.
Any other questions, send us a PM.
Also have
- 1x RB26 OEM BOV/Recirculation Valve available, with mounting pipe.
$40
- Stock Stagea rear upper camber/control arms, left and right side.
$30 for the pair
- Stock Stagea front and rear swaybars. Rear bar comes with stock links.
$30 for the pair
