1995 Silver Manual Coupe R33 GTST Series 2 Pushing 220 RWKW nice 18's on her and most importantly RWC. I think he might need to change that airbox for RWC. We'll see. He's an SAU member as well, saw this thread and contacted me. Not worried about the slight front bar damage for now, guy just had it resprayed before it got done in car park or some such.
Edited by jukic.j
Haha my knowledge is also not awesome but my understanding is that it's called a front strut brace and it is put there to stop flexing andprovide rigidity between the two suspension strut towers. This improves handling, reduces tire wear and reduces metal fatigue.
Basically the handling feels more precise and responsive.
Funny it's the fanciest looking thing on the car isn't it haha. Some people actually install them just for the tuner look.
Edited by jukic.j
right, thanks that makes sense and knowledge has increased +1!
that's awesome because I like the look of it (i love metallic blue) and also it actually serves a purpose! will look at getting one ahahhahah
a civic........HAHA.
shopping for a 34 though.
Yeah I noticed some of your posts, I was looking for an R34 but it wasn't worth the price difference IMO. I'll get an R34 when I can afford a GTR
I hope it doesnt have airbags after seeing the cooler piping :whistling:
Ok ok you got my attention, obviously as a series 2 you know it has dual airbags. Spill it, what do you know. WHAT DO YOU KNOW~!!!! lol
Edited by jukic.j
Cut hole in the battery tray is defective and being a model with airbags it can't be engineered I'm pretty sure. Uv bought it with rwc so just be careful not to get done :ninja: . Good luck, car looks alright though.
Wellll I haven't fully bought it yet. Have paid $500 deposit and signed a contract to buy it with a RWC. how can I get done for anything if it has RWC? or will RWC address this issue? Can't you get a flange to reinforce the hole and that makes it legal? If It has a RWC do you think I get to get it mechanically inspected pre purchase style?
It's tuned to 15PSI but no wideband should I get a wideband ASAP?
Edited by jukic.j
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
    • OK, now we are ready to get started. You need to remove the air boxes on each side for clearance. The cover is straightforward, undo the clips on the top and lift the front cover out of the rest of the housing. If it is tight you can remove the air filters first. The rear section of the airbox is trickier. On each side you need to remove the Air flow meter wiring which is held to the airbox with a clip; you need to get behind the clip on 2 sides if you want to remove it without breaking it - unclip the harder side and pull on the clip with medium force, then unclip the easier side and it should pop out The airbox is held onto the intake hose with a spring clamp; you need to get a flat bladed screwdriver behind the spring on both sides and pop them outwards. When you have got them in the right unclipped place they will stay there and the airbox slips out pretty freely. Put a rag in the intake to prevent anything getting dropped in there, and also to prevent you seeing that the turbo seal is leaking oil (as they do). Then. The top of the radiator is held by a steel plate, it is secured by 2x10mm and 2x12mm headed bolts . Remove them and remove the plate Also grab the bushings that hold the radiator to the plate on each side so they are not lost!
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
