Looking at the hicas dash light is getting old and I don't want to have to explain the process at rego inspections .
I searched and found this thread which reckons you go to the Hicas computer (R33 GTS25T) under the rear parcel shelf and cut the Green wire with the White trace .
http://www.skylineowners.com/forum/showthread.php?t=105358&page=2
Has anyone tried this here and found it works . If so it has to be easier than stuffing around under the dash to get rid of the light .
Thanks in advance , cheers Adrian .
But if you pull the dash light out, It won't tell you if there aren't any other faults with the power steering. eg if the reservoir is low on fluid the light will come on.
Open the bonnet and check it?
Kidding right?
The light is already on due to HICAS removal... is the light going to change colour or get brighter when a fault happens else where?
Tomei Hicas lock kit is another consideration, will also allow you to return to stock fairly easily should you require.
I'm just getting into Skylines and picked up an R33 GTSt for a great price off my brother as it has HICAS issues. I have bought the TOMEI kit but am wondering if it works as a "quick-fix" or is it only useful if your HICAS was functioning correctly?
Afaik only really useful if your Hicas is working.
Save ur money and buy a drift works hicas eliminator kit from cartel online. It will eliminate all ur hicas problems and I'll reduce the weight of ur car
From what I have read this won't pass a roadworthy inspection though?
haha, Bit hard to 'save money' when I have already bought the TOMEI Eliminator. Ah well, will give it a go, since I've already bought it, and if it fails, will have to try the Driftworks kit. However, will this still result in having the HICAS light on? and perhaps power-steering issues? Perhaps combined with the electronic part of the TOMEI kit this could work (Or at least use the TOMEI just to get through the roadworthy then use the Driftworks kit)?
Not really worried about saving weight anyway.
Edited by falconhoon
Found this on another forum, describes HICAS problems that were solved with TOMEI Lock kit, so at least it is a little bit promising.
But then again other people in that forum just recommend the Driftworks kit... Damn advanced technology in older cars, but can you do hey? Will get it sorted one way or the other.
03-10-2010, 02:14 PM
my hicas used to do weird things to me as well once I hit 80 km/h. the steering wheel would turn a good 40 degrees just to keep the car straight. I was pretty much crab walking down the highway. for a while I kept checking everything out and still hadn't found a solution. eventually I just installed a Tomei hicas lock kit and was done with it.
my advice would be to lock up the hicas and not spend hours trying to find out what the problem is.
http://www.gtrpwr.co....php/t-921.html
Might just get the ECUTALK Consult/USB cable and figure out what is causing the trouble if I have too.
http://www.skylineow...t=105358&page=2
to answer your question this works a treat. have done it on several of my cars including r32's :D
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
