My 96 rs4 stag has had a problem since I have brought it , driving specifically between 85-115kph, I would estimate, I have a shuddering or 'pulsing' sensation coming from what I believe to be the rear axle of the car. Like additional torque is being applied to the rear driveshafts momentarily in an on/off fashion. I would say that it is not a reducing speed sensation, as in abs acting on the rear wheels for some even more bizarre reason, especially as it only happens at a light load throttle position and the sensation is destinctly coming from the rear end. Also it only seems to only happen when it's been running for a while or fully warmed up. Anybody got any suggestions or ideas as to what could be causing this to happen?
https://www.sau.com.au/forums/topic/412934-stagea-100kph-pulsing-shaking/
Is it an awd car? Are all your tyres the same size and type? Tried turning left and right and listening for wheel bearings? Jack the car up and have a look? Wheels binding (foot or handbrake)?
Yeah it's awd and yeah all same tyres and same size. I can't hear anything while I'm driving. And it doesn't feel like anything binding up. Like I say it only really starts happening after driving for 20 mins or so and can only notice it at higher speeds
But thanks for your suggestions
Will be rest tyres are worn slightly more than the fronts
Mine is doing it ATM so I have had to make it rwd till I sort out new tires
Funny thing is that they aren't even that worn but the fronts are brand new
First up, I'd get the wheels balanced. This will shop up 90% of your problems. If the tyres are unevenly worn, the tyre shop will tell you (they like to make money). Uneven tyre wear can cause the AWD system to start sending torque to the front when it's not needed. If the rims are buckled or out of round, they'll tell you. The other thing it'll fix is unbalanced wheels.
I've had a vibration caused by all of the above.
  • 5 months later...
hhhhrrrmm sounds like my issue around 100 KM/S + -,the car shudders like it doesnt know what gear to select.
im about to have a shift kit fitted and oil changed ill let you know if this fixes the issue i think it is, which is oil thats lost its viscosity and causing the auto to do silly things. if it does fix this issue try sending a message to Jetwreck, he is doing all of my work as i cant be fkt, coz im lazy................... Actually I just read your sig and it says ur in Auckland and im pretty sure he wont go there unless you pay for it. but it might be worth asking him for a decent oil for your auto unless you know of one your self?
Edited by loymclure
I had this problem too, in my 2000 S2, really annoying and sometimes felt like the car was jerking back and forth at 80 - 100 km/h, turned out to be a really simple fix, check the attessa fluid level in the reservoir located in the back behind the inspection cover on the right hand side, make sure the engine is running as it will appear full if the engine is off, topped it up to the correct level with ATF/ power steering fluid, problem solved. Regards Craig
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
