  • Replies 41
GRRRRRrrrrrrrr..... :rofl:
You'll keep.
Adrian
lol... i wont go near the track as ppl keep telling me ill run 11s, but i know for a fact ill be lucky to crack a low 13s...say hello to the space cadet behind the wheel and pedals :(
Im trying to get a 2 stage rev limiter for my car, so i can cheat when trying to get the thing to launch properly...and yeh i have read the thoughts of others on this, but its my car, my coin, and the engineering of getting something like this set up and working well appeals to me more then the pedal work involved....
So what was that about the launch controller you were using?
Matt,
How are your gear changes now?
I remember you saying a while back (216rwkw) that you grannyshift a little. :(
Hmmm... I probably shift a little more like a mid to late 40yr old mum now, certainly not MILF quality either :rofl:
But seriously, I still shift a tad softly. Any drag meet that I get to 'drive' the car home from is a good one!
At $1500 a pop I wouldn't be driving mine like I hate it either. ;)
My poor ol RB20t gearbox has been on its last legs for quite some time now, its just waiting for something to push it over the edge.
I have just the thing :)
just like I'm "assuming" I can do better... You're "assuming" I can't.
Listen matey, I've done what I talk about. Have you? Let your timeslips do the talking.
Roy, IanH uses the Power FC Pro in his GTT. It has launch control built in. You can hold the pedal flat and it will only rev to the pre-set level.
Adrian
your drag strip is concrete? hmm..
hard to tell from the vids.. just bouncing off the rev limiter probably chokes the car a bit after launch wouldn't it?
I think one launch in your vid was a low 2.x time which is not too bad.. should be able to get you a mid-13 from what i see from the SAU list if everything else is right.
What types of modifications dso you have on your car? Doesn't really seem to be taking off that quickly after the launch really, i think the mid-range is letting you down. What sort of tune has it had? do u have a dyno sheet? Maybe its just building too much power up top-end and not enough down low-mid end?
I wouldn't worry about trying to perfect the car at this point in time.
The driver needs the work.
I don't mean that in a derogitory (don't knock the spelling) way but until he's running consistent times at the peak of the current set up which may be @ 13.5, then what has he achieved.
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
    • Hi, I need same this wing nismo , Does anyone have one for sale?  if any one have can contact me  00966546888343
    • Nah, lots of insurance repairs on V36 and V37 for pedestrians deployments. Reasons ranging from possums, to extremely severe potholes have deployed them. However, paying for the full repair can still be upto $5k AU some people have noted!
    • Hi, i got 1998 r34 4 door auto abs model and its manual converted with bigbox when i bought it . I successfully find the neutral and reverse light wire but can’t find the speed signal wires for speedo drive. I know its grey plug but on my loom no grey plug with 2 wires . I opened the loom upto where it getting branch with other wire, i’m amazed they is no wire. So need help how to fix the speedometer problem. I search on google it says some r34 model measure speed from diff sensor. Is it right? I talk to a wrecker he say no this isn’t right, i’m kinda stuck. Please help
