Hi guys, having trawled the internet for the past day this forum seems to be the most helpful so i figured i would give it a go posting here.
I am having trouble with my 2002 RX250 (M35?) stagea. Twice in the 8 months i have owned it, it has felt like it was going to stall on me. Without moving my foot on the accelerator it has surged and then dropped off. Both time this happened was as i was pulling out of my driveway and up the hill i live on so the car was cold both times.
On both occasions the check engine light has come on. The first time the car would not start for about 2 hours, the second time which was only yesterday it didn't actually stall and i was able to drive home no problem however the check engine light is still on. From what i can tell (i only found out about the ECU fault codes reading the forum today) it is coming up with a 0340 code (i will upload a video of the light blinking to YouTube later if anyone doesn't think this would be correct).
As i didn't know that i could check the codes myself i had no reason not to believe the garage who serviced it (part of the second hand dealership i purchased it off) when they told me that there was nothing physically wrong with the car and that sometimes gremlins like this occur and that it would probably never happen again. It was within the warranty period last time it happened but its not this time. I am taking it to them in 2 hours to get them to look at it again, if they tell me that there is nothing wrong again is this likely? Or is there an issue here that needs to be addressed before it causes any major damage?
Any advise on what i should do from here?
replace the two CAM sensors on the back of the motor. no physical damage should occur, but its a PITA to drive like that. and when it doesn't start................ well, ask craig about that one!
Its going to the mechanics in about an hour so I am going to ask them to replace the sensors not just reset the ECU this time. Hopefully that will fix the minor annoyance of the car surging sometimes while I am driving along the long boring road to work
Now that I have an idea of what's wrong I will. Last time they told me that they didn't do anything as they couldn't find anything faulty. I just hope that this solves the issue as I really love this car and its a shame to have running issues with it as its my daily driver
How unusual for a workshop to not know what they are doing with an m35.
If you have the money replace all three sensors with genuine Nissan parts.
Deadpan sarcasm! Surprised, but did enjoy ;)
Also, besides replacing the two cam sensors and the crank sensor, check that the prongs on the connectors are nice and straight. I had this error a long time ago and it turned out that the prong on the connector was bent.
its entirely possible that your car didn't receive the recall to have them replaced from factory. check the engine bay plate, make sure it has two round silver dot things on it. anyway, they will still need replacing, or at the very least checked, before the car operates correctly. resetting the ECU is NOT a long term fix.
So after hooking it up to their computers they determined that its an issue with the variable valve timing (there was more than one error code it would appear) gotta pull the front of the engine off now I guess
If it was the VVT wouldn't it do it more regularly than twice in 8 months? What exactly would I look for and where to see if it got the factory recall to replace the cam sensors?
As Iain said, find the build plate in the engine bay (drivers' side wheel arch) & there should be 2 round silver stickers nearby, each about 7mm across.
One of mine says R186 on it, the other is blank.
You could just learn to reset the ecu yourself, that way it doesn't cost you a cent. :)
Ok so hopefully my final update. The CAM sensors were replaced today. It feels like a different car almost, no random loss of power while driving on a straight flat road. Only time will tell if its fixed the random stalling problem I guess. Just wanted to say thanks to the community for all your input. I honestly wouldnt have known where to even start if it wasnt for you guys. Cheers
They told me they replaced the CAM sensors. My wife took it in for me while I was at work so I didn't actually see them do it and I cant tell the difference myself but it seems to be working all good now :woot:
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
