hey mate just a quick noob question,
when I jacked my car up on a hoist, and in N, the rear right wheel spins by itself, if I put my hand to it and hold it still, the rear left wheel starts spinning,
what sort of diff do I have?
cheers
Open diff (single spinner).
I can tell you're doing this with the car on though - if you turn the car off, in D, grab a wheel and spin it - the wheel on the other side will spin the opposite way.
On an LSD, if you do this, both wheels will turn the same direction.
Another more enjoyable test is to go on a patch of gravel, reef the wheel to full lock and stomp on it – an open diff will spin the inside wheel and you'll move forwards in a slow circle - an LSD will spin both and start whipping you round hehe.
Edited by SMOKEYC34
There is no adjustment as far as I know, they will probably need to take the shims out from behind the line pressure spring in the valve body.
Perhaps a slightly thicker transmission fluid may help slow the clutch actuation down?
its just second that needs reducing. third and fourth feel pretty much unmodified
I've had cars with open, viscous, 2 way and helical lsds and I'd say the best all rounder is the helical
Nothing puts hairs on your chest like going around a large roundabout in the wet with a nice tight 2 way :P
Lol. Wait until you do that in a car with a 'lokka' diff. Mate had one, they're like a button clutch - their either on (full locked diff) or off (open single) - its just not very predictable as to when the switch takes place - you can be going brought a bend, put in a tiny bit of power and all of a sudden you're in full locked mode and you're looking out the side window. Awesome or straight line work though.
Sorry for o/t.
Who in melb is best recommended for the trans go?
I was sure I had found something about the diff specs of different V35 cars a couple years back. I know that the old diff in my car was crap and constantly peg legged at the drags/lit up the inside wheel when going around a corner at the track
If you can find an auto v35 that can throw down 2 black lines at the same time with the stock diff ill take my hat off to it who knows maybe a factory option, either way viscous sucks balls
I get em on the hoist all the time.....both wheels spinning in the same direction to me means a LSD. I've done many a launch with the traction control off and they always light up both.
Spool for the win but its a pain on the street.
Edited by Jetwreck
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
