Got my cooling mod on the car on Sunday. Other that a small problem with my Knock sensor being F#$ked and having to pull the top end off again it all went well.
Pretty easy to do IMO.
My setup is:
Mishimoto Rad
Mishimoto 12" Thermos and shroud
Nismo low temp thermostat
No engine Fan
Scott's Coolant bypass
Electronic temp controller
For the first time in a long time I was actually able to keep the A/C on without my temps getting up over 92 Degrees at idle even today when it was hot at times. With the A/C off though the car is sitting on about 79/80 on idle. If I get up it the temps do go up to about 85/86 and stays there, the recovery is extremely quick. All over i'm feeling a lot safer with this on....I should have done it ages ago.
Bleeding is very easy but I will suggest to go and get a fitting to go into the top of the bleeder so you can fit a tube onto it.......IMO Scott should supply this! :P
Well done Scott.
What is your oil temp when you give it some stick?
Around town with the Greddy setup I have its about 90 degrees most of the time. After a rather spirited drive(hard drive for most) probably about 92-95 depending on the weather. On the track I would expect to see 100-110 after about 5 laps also depending on the weather.
Why the question on Oil?
Mine is f*%kn leaking apparently. Hope to get the car back from AM Performance tomorrow, then I'll have to pull it all apart again... f*&ker!
Where's it leaking? Can't you do it at home? :P
It only took me about 10-15 minutes to get back down to the gully! I move the whole injector rail and intake as one piece though
It's leaking in the valley by the sound of it. I bet its that farking Proflow fitting in the valley. Yeah I'll do it at home this time.
Didn't think of moving the injector rail and intake as one piece. Might give that a crack.
OK......so I've done my first real spirited drive(Alec I had a clear run down the test track! :P).
Water Temps sat at a perfect 79-80 degree's the whole way(oil temp 98)....I was also on high boost which is about 24-26PSI. I got stuck at one set of lights after a heavy hit uphill and the recovery was awesome.....the highest I saw was 82 degrees while on idle but the thermo's dropped that back down to 78 pretty quick.
The other thing I have noticed is now my A/C doesn't creep about 84 degree's when on stuck in traffic(I run thermos).
Finally the cars temps are under control! :)
As I said before Scott this is an awesome mod and one well worth doing imo!.....It almost needs Nismo branding! :P
For anyone living in the hotter states or wanting to go on the track this is definitely something you should be looking at for the longevity of the motor.
Ryan - The only correction I would make to your install is to not remove the injectors. Simply unbolt the lower intake and move it out of the way as one complete unit. As mentioned further above it takes me about 10 minutes to get down into the gully of the motor.
Leak fixed, temps perfect now.
Leak was a loose proflow fitting on top of the valley. Re-tightened it, sucked all the coolant out of the valley, and pressure tested the radiator. Away we go!
Temps are now a stable 90 degrees even with the air con on flat out. MUCH BETTER!
Oh, and Scotty: hose is about 36cm long. How long have you been supplying them?
Only about 3 weeks now... lol.
Good to hear you found & fixed the leak. Getting quick @ removing the plenum are we?
Lol I meant how long a hose has Scott been supplying. But thanks :P
Not quite Craig's 15 minute figure, but only a little longer. Better without removing the fuel rail, for sure.
I think the last one I did was only 260mm long. I have the block fitting pointing towards the bleeder, it makes it a little shorter and gives better clearance from the exhaust.
Definitely do the proflow fittings up tight in the vice first, with a little lubricant. Don't try and tighten them in the car, it will come loose and leak.
My block fitting points towards the bleeder, but 26 might be too short? Be interested to see pics of how that sits.
Fittings are fine now, but a PITA to tighten properly in the car.
  • 6 months later...
Well after running the Mishimoto 12" Thermos and shroud for the last 6 month's I have made the decision to change back to the fan.
My car with the thermo's has been running in between 86-93 on normal running(including freeway). I recently went down to Kiama and went through the mountains only to find that when I got to the top even though I was not up it the whole time I spiked up to 104.
So with the fan(no shroud yet as I will need to make one to suit my Rad) my car's temp is now 74-79 in traffic and around town. I also had the chance to give it a good hit up some hill this morning only to find that the max temp I could get to was 81(I normally get to 93 on the same hill). On top of that the whole engine bay seems to be cooler.
I have to say don't waste your money on taking the Fan off and only running thermo's.
This supports my long held belief that thermo fans, regardless of the wild manufacturer claims; are nothing but hot air.
Anecdotally, a clutch fan can flow 3000cfm of air at peak, whereas the best I've heard of out of a 14" thermo is around 800-900cfm (nothing like the 3000cfm some manufacturers claim).
Even with 2x14" thermo's you are more than 33% down on airflow.
The advantage with the clutch fan is that it is constantly expelling hot air from the engine bay; rather than thermo's which need to wait until the engine starts to heat soak; then they have to try to drag the temp back down.
If the fan clutch is in good working order; they present little load on the engine until they are needed, and very little impediment to response.
Yes, a pair of thermo's might (might) provide more airflow than a clutch fan at idle; they will NEVER provide the same flow as a clutch fan at 2500rpm (most start to freewheel above that; as they are at their optimum flow rate).
Up a hill (low speed), in traffic, under repeated hill start loads; a pair of thermos just cannot keep up with the heat that our cars throw into the cooling system.
The one thing I did like about thermo's when I was running mine; was how quiet the car was on the freeway.
But that's not enough benefit to me.
I'm actually running a GKtech fan with an SR20 clutch; which is even more efficient than our stock fan.
Nah, forget about it.
Not worth changing our design. Bigger radiator, low temp thermostat, and coolant mod is enough for the car never to get hot. And that's even on the track I believe.
Oil temp on the other hand, needs a bit of work to keep down.
Alex; question.
Do you know if the PNM fans run (even at low speed) prior to reaching temp?
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
