So looking at putting coolant my skyline because it getting hot when using only water (coolant leaked then I replaced it with water, hence the heating issue, as there was no issues before when I was running coolant).
Can someone recommend a coolant they have used or a coolant you would advise NOT to use. I have heard organic coolant is good, you basically buy a small bottle then add it to the water in your radiator, anyone used this? I believe it's similar but a bit different to antifreeze/antiboil. Any ideas suggestion advice etc is appreciated, cheers!
https://www.sau.com.au/forums/topic/413769-which-coolant/
I use Genuine Subaru (Castrol) Anti-Freeze/Boil coolant. Only cause I get them free ;)
I wouldn't use cheap $5 coolant from Supercheap. From my general knowledge, if you use a coolant that isn't antiboil rated, what happens if it boils? it creates pressure and could crack your rad. I could be wrong, but just my opinion. Just use a decent Castrol Anti Freeze/Boil coolant and you'll be fine.
https://www.sau.com.au/forums/topic/413769-which-coolant/#findComment-6626548
Thanks everyone. I've noticed it's been "using" water (I fill up the water then after a while of driving I notice the temp goes up and check the radiator and it's quite low, it's happened twice now, first time I thought I didn't fill it up enough and there was air bubbles). I can't see any leeks anywhere even when it's hot. At first I thought because it was only water not coolant it was evaporating once hot (maybe out of the radiator cap as it was hissing when the car gets hot) but that's not even possible is it? Any ideas on what it could be?
https://www.sau.com.au/forums/topic/413769-which-coolant/#findComment-6626625
I've also been told not to use water since it can create rust or algae (in the reservoir) in extreme circumstances, UNLESS it's distilled water. But then again, just don't use it. We have coolant for a reason.
Did you do a proper bleed? If not there may be air bubbles sitting at the high points of the motor. if you drain the coolant completely, it would take about 7.5 Liters (well for my RB25DE Neo in R34 does anyway) to fill it up. If you did a proper bleed then your radiator most likely has hairline cracks in it and only leaks when your driving at 60KM + when coolant is heated up, creates pressure and forces the hairline crack open and seeps out. Doesn't do it when its idle or off since its cooler then and less pressure.
It happened to me before and I changed the rad, no problems anymore
https://www.sau.com.au/forums/topic/413769-which-coolant/#findComment-6626759
Nissan long life coolant can't go wrong
^^ this ! nissan LLC is in concentrated form when you buy it from nissan, when you add the recommended amount of distilled water to it it works out to be good value too
https://www.sau.com.au/forums/topic/413769-which-coolant/#findComment-6627269
Awesome I'm gonna try the bleeding the water/coolant too, didn't know there was the bleed valve near the plenum lol, I'm also gonna run the heater. Maybe a dumb question but does autobarn or supercheap sell nissan LLC? Or am I gonna have to go to nissan?
https://www.sau.com.au/forums/topic/413769-which-coolant/#findComment-6627272
My stock HCR32 was filled with water when I got it, don't know how long it was in there, but it didn't have any effect on engine temperature, has never been over 85 C and that's while monitoring through consult whist going for a thrash. Have since drained and replaced with the Nissan coolant and temps are the same.
https://www.sau.com.au/forums/topic/413769-which-coolant/#findComment-6627298
Plenty of people run pure water with no issues.
https://www.sau.com.au/forums/topic/413769-which-coolant/#findComment-6627519
im surprised people run just water and havent had too many problems.
Water boils, then evaporates, thats one of the reasons of coolant its anti-freeze and anti-boil
Doesnt freeze over at cool temps and Doesnt boil like a kettle at hot temps
For a few bucks, it gives you peace of mind.
https://www.sau.com.au/forums/topic/413769-which-coolant/#findComment-6627913
I was always told. Most 'coolants' are actually an anti freeze(ethylene glycol) and lower the boiling temperature of water. In warmer climates you can get away with just running distilled water and a corrosion inhibitor
I have been doing this for years with no issues, its only like $6 for the inhibitor too! Apparently ethylene glycol can catch fire if you have a high content mix and it sprays over a hot exhaust manifold or similar..
https://www.sau.com.au/forums/topic/413769-which-coolant/#findComment-6627980
You water temp. would only sit around the 80 degree area anyway. Even if the water temp. reaches 100 degrees the pressure in the cooling system raises the boiling point.
This is why it's important to replace old radiator caps that don't hold the right pressure anymore.
https://www.sau.com.au/forums/topic/413769-which-coolant/#findComment-6628115
^^^i would be suprised if this was the case for long. . .even distilled water will cause corrosion/ironise on an iron block RB
Do a bit if searching on the forum, it's been talked about plenty if times.
And as for temp issues, no there is no temp issues running just water. As said by someone else, the increased pressure in the system raises the boiling point. Generally cars run about 1 bar of pressue in the system, meaning the boiling point if water is over 120 degrees.
. The majority of coolants are only corrosion inhibitiors, and sometimes anti-freeze. You can still boil the coolant at about 100 degrees if you have a faulty cap.
https://www.sau.com.au/forums/topic/413769-which-coolant/#findComment-6628661
No doubt it has been "talked about" i tried running (only)distilled water in my rb and a week later it started to go brown, no doubt corrosion between the iron block and the water hence why corrosion inhibitors are used by the factory, if they could get away without the expense/necessity of using it they would
https://www.sau.com.au/forums/topic/413769-which-coolant/#findComment-6629188
Its smokey and the distinctive smell of burning coolant goes everywhere, but thats about it.
https://www.sau.com.au/forums/topic/413769-which-coolant/#findComment-6629222
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
