Hi i would like to know if anyone has tried the rb25det D-jetro Power FC as yet. (R33 RB25DET)
1. what is the MAP sensor limits 1 2 3 bars?
2. Can i still use the AFM if needed.
3. Is there launch control.
4. Can the old Data logger work with it. or software update needed??
5. what do you guys think about it.????
thanks for your time and consideration.
https://www.sau.com.au/forums/topic/413899-rb25det-d-jetro-power-fc/
He was asking if it was the one that Nengun are advertising. I was going to purchase the same one, but Callan explained to me what it was and made it a bit weary.
::EDIT::
Yeah they do, Scradly... Check it out on the Nengun website.
I have always love the power FC just because it’s a vehicle specific stand alone, and easy to tune. I have Motec and Haltech PS2000 ecu's, but want the D-jetro model power FC. I tune them myself.
yes mate the one from neugun. they on ebay to, and poping up all over slowly.
were is Paulr33 he is a Power FC guru. lol
come on mate keep it comeing.
Edited by MJTru
I was asking so I wasn't providing answers for
something different..........
As far as I remember its a 2 bar map sensor
There is no launch control
You can use afm if you want
No idea but fc edit should work
They are a re-flashed 26 d-jetro and if you do the data init you have to send it back to nengun so they can re-flash it. Other then that you get everything to make it work on a 25 with map and IAT
That is interesting Mate, talk about a turn off. I got a rb26 Power fc to work on a rb25 and i had to use a MSD trigger switch to retain the VTC. But that was on a L-jetro. I also have a D-jetro rb26 power fc. now i'm woundering if i should try to make that work insted. I hacked a extenstion harness that goes inbetween the ecu and the factory harness. I should still have the harness.
Do you know it the unit will have VTC, even after reflashing it. ?
if its a 2 bar map is it x 2???
i see a video on youtube by nugum, you can check it out.
thanks a million for the info. anyone else. Were is the guru paul R33 he has to update the Power FAQ with this unit. lol
Paul probably doesn't know much more then what I've told you as I dont think anyone who has bought one has put the information to paul or put it in a public forum.
I looked for answers and nearly bought one and was going to provide these answers to Paul but I didn't get a tax return that year so didn't worry about it.
Thanks mate i will do the same, having APEXI reflash a gtr power fc is ok with me, as long as they stand by their name. The only thing i want to conform is if the, fact that if you reinitialize it, I will have to send it back to APEXI to reprogram??? This makes no sense in my head, and BE Apexi they wouldn’t do that because it just simply makes no sense as to many units will be sitting in their offices. If you listen to the video, he mentioned that people mess up the settings and send it back, and all they most of the time do is reinitialize it.
will update as soon as i kill The old FC reasults, and unit arrives.
I told you, you have to send it to Nengun to get reflashed, not Apexi.
Nengun reflash it to work
It's not a problem as long as you dont do data init. There's no need to do it as long as it stays on the same car and the idle learn is done correct first time
only a 2 bar map sensor... so one bar of boost and your back to old limiting issues of the L anyway...
what a way to waste your cash... just get a decent ecu and run 2 fuel maps at least then you can have a 3 bar map sensor.
the apexi standard map sensor is a 3 bar map sensor. but dont be fooled. this doesnt mean you can run 3 bar boost.
map sensors (all not just apexi's one) are rated in total pressure and not positive pressure or "boost"
3 bar map sensor means -1kgcm2 for vacuum and +2 bar for positive pressure
so if you want to run more than 2 bar boost using the apexi kit you need to change the map sensor and recale it using datalogit
no you cant. models are fixed. ljetro is afm, djetro is map. you cant mix and match or change
no there is not
yes datalogit will work
same as ljetro but with map sensor input instead of airflow meter
some tuners swear by apexi djetro and others hate it with passion
ive heard more good stories and tuners talking good about it vs those talking bad
the main thing that is crucial is the installation, dont f**k with the install or be a spaz
read the instructions and install it as per how apexi intended it to be installed
most issues come back to how its installed
sorry and just to check also is the an APEXI legit product or a special nengun release?
i always questioned this and it wasnt clear
IF its a legit APEXI release you should be able to DATA INIT when ever you like
If its a non legit release and you have to send it back when you want do DATA INIT each time I would advise caution with this product
this sounds worrying and i would not purchase this. DATA INIT can help to fix f**ked idle and other issues
there should be no reason a legit Apexi purcahse requires re-send to supplier to do DATA INIT
youve been warned and i would question this
this sounds like its a BCNR33 powerfc djetro with a special remap to make it work on ECR33
vs a legit ECR33 powerfc djetro version where you can DATA INIT as much as you like
it doesnt make sense because DATA INIT would load from its nvram
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
