I was asking so I wasn't providing answers for
something different..........
As far as I remember its a 2 bar map sensor
There is no launch control
You can use afm if you want
No idea but fc edit should work
They are a re-flashed 26 d-jetro and if you do the data init you have to send it back to nengun so they can re-flash it. Other then that you get everything to make it work on a 25 with map and IAT
sorry and just to check also is the an APEXI legit product or a special nengun release?
i always questioned this and it wasnt clear
IF its a legit APEXI release you should be able to DATA INIT when ever you like
If its a non legit release and you have to send it back when you want do DATA INIT each time I would advise caution with this product
this sounds worrying and i would not purchase this. DATA INIT can help to fix f**ked idle and other issues
there should be no reason a legit Apexi purcahse requires re-send to supplier to do DATA INIT
youve been warned and i would question this
this sounds like its a BCNR33 powerfc djetro with a special remap to make it work on ECR33
vs a legit ECR33 powerfc djetro version where you can DATA INIT as much as you like
it doesnt make sense because DATA INIT would load from its nvram
This is how I was told it was, I'm not sure who is doing the reflash (As in if its someone from Nengun or some tech firm in Japan doing it) but they wont release the data to update it to the power FC for yourself (For obvious reasons) which is the main reason i was put off
Other then that the kit comes with map sensor IAT sensor and everything you need to plug it in and go
Having said that though, I cant find it on the Nengun site anymore.....
it just sounds like a beginners trap
ive seen people data init by accident and ive seen friends play with the hand controller and data init too
data init the unit once
and its basically a paperwork which needs to go back to nengun to be fixed
if you data init and your away from home theres no way it will start on BCNR33 maps and default tune
so youd have to tow it to get it home. ASS
it should be on the nengun site under NOP
dont get me wrong
its a massive breakthrough in being able to basically do what AP Engineering were doing
but its ass that when you data init, its a bcnr33 powerfc
i actually wonder what is being changed on the pfc to make it work with ECR33
if theyre just parralleling up the input sensor to make it work
then technically if you data init the unit and enter a series of key presses on the hand controller this is probably the same thing
ie does the djetro ECR33 come with some special firewamre that actually says ECR33-D in the /etc/version or does it just say BCNR33-D and its just a series of tune settings
if its just tune settings you could do it yourself with a bunch of key strokes on the hand conrtoller
sure it would take a while, but would save posting it to nengun
Hi i would like to know if anyone has tried the rb25det D-jetro Power FC as yet. (R33 RB25DET)
1. what is the MAP sensor limits 1 2 3 bars?
the apexi standard map sensor is a 3 bar map sensor. but dont be fooled. this doesnt mean you can run 3 bar boost.
map sensors (all not just apexi's one) are rated in total pressure and not positive pressure or "boost"
3 bar map sensor means -1kgcm2 for vacuum and +2 bar for positive pressure
so if you want to run more than 2 bar boost using the apexi kit you need to change the map sensor and recale it using datalogit
2. Can i still use the AFM if needed.
no you cant. models are fixed. ljetro is afm, djetro is map. you cant mix and match or change
3. Is there launch control.
no there is not
4. Can the old Data logger work with it. or software update needed??
yes datalogit will work
5. what do you guys think about it.????
same as ljetro but with map sensor input instead of airflow meter
some tuners swear by apexi djetro and others hate it with passion
ive heard more good stories and tuners talking good about it vs those talking bad
the main thing that is crucial is the installation, dont f**k with the install or be a spaz
read the instructions and install it as per how apexi intended it to be installed
most issues come back to how its installed
Hope that all is well, thanks for just keeping it simple, you were always good at that. lol
Cause of you i'm a good Power FC tuner. thanks a million,
after the item arrives i will tell you all what i think of it.
do you know if it has two map sensors like the RB26 Power FC???
I'm pretty sure that what they'd be doing is mashing the normal RB25DET FC's firmware with the 26 D-jetro firmware, taking what they need from each. So, they'd want the code that handles the MAP sensor and IAT and turns it into the load index from the D-jetro firmware, and they'd want the code that handles all the rest of the RB25 sensors from the 25 FC. Massage a few things so that it works with only one MAP sensor (shouldn't be too hard), and you're away. Probably have to do the same with a few other little things like idle control and whatnot as well.
There's plenty of clever people around who do that sort of hacking these days. The best (oldest) example was mashing the Canon 10D firmware into the 300D to open up a range of features from the higher end camera on the lower end unit. They had to pull some tricks to access some of the features using buttons the 300D had, because it didn't have the actual buttons that the 10D had.
thanks mate i raising help with them right now with all your points. I have a family member in japan that is helping me and i asking for a full refund.
so sorry i wont be able to add any more info. That sucks.
Paul33
i made a rb26 PFC L-jetro work on a ECR33. now I'm wondering if i can make it work on a d-jetro version as well????? i guess it would be a good task to try. have you heard of anyone doing it. The vtc was controlled by a MSD trigger switch.
thanks to everyone
I thought the 26 d-jetro's only had one map sensor anyway. There is no need to moniter the manifold pressure with 2 pressure sensors....
bcnr33 (or any gtr) djetro has twin map sensors
the powerfc uses both map sensors and both should be installed and used
people have gotten the GTR powerfcs working RB20/RB25 no problems and it requires some exrtra work
the main difference is they are cutting wiring, splicing wires, changing a heap of settings and doing all the tuning
its not off the shelf and the cars loom would be modified to suit, or a boomslang in the middle modified
a few years i actually bought a boomslang cable and the supplier was happy to template from what i had done (wiring changes) to make a GTR pfc work on ECR33
so you could basically order a BCNR33 PFC and this special boomslang and punch in a few settings and it would work on an ECR33 but i never got around to it
this was when mafia got a stock BCNR33 working on his ECR33 properly. this was back when ECR33 was discontinued
Ah thats right I remember seeing the 2 map sensors when I looked at the instructions for my boost control kit. Is the point of having two purely because there are usually 2 MAF Sensors or is one for boost control and one for calculating load?
This is probably in your FAQ, I'll have a look :)
Someone link me to the ecr33 d-jetro? I can't find it on the site anymore
Apexi MAP sensor is 1.7 bar (at ~4.5V) boost pressure sensor.
You can connect any MAP sensor, as long as:
1) you have the right connectors on both ends when making custom wiring harness.
2) know the sensor parameters. See http://1jzmerc.com/hks-faq/hardware/#map for a list of MAP sensors and parameters.
D-Jetro RB25DET PowerFC (4E14BN32 and 4E14BN33) is legit - but limited to Power Excel workshops - according to http://www.apexi.co.jp/pdf/products/p_fc.pdf
if its a legit product then you should not need to send it back to apexi or nengun when you do DATA INIT
i cant image any ap engineering model needing to be shipped back for DATA INIT
so if the one you buy requires to be shipped away for DATA INIT and its "legit" then its absolute ass as per my previous posts, beginners trap
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
