Felipe Massa and Esteban Gutierrez have both been handed three-place grid penalties for impeding rivals during qualifying at Barcelona.
Revised Grid
01 Nico Rosberg Mercedes 1:20.718
02 Lewis Hamilton Mercedes 1:20.972
03 Sebastian Vettel Red Bull 1:21.054
04 Kimi Raikkonen Lotus 1:21.177
05 Fernando Alonso Ferrari 1:21.218
06 Romain Grosjean Lotus 1:21.308
07 Mark Webber Red Bull 1:21.570
08 Sergio Perez McLaren 1:22.069
09 Felipe Massa Ferrari 1:21.219 *
10 Paul di Resta Force India 1:22.233
11 Daniel Ricciardo Toro Rosso 1:22.127
12 Jean-Eric Vergne Toro Rosso 1:22.166
13 Adrian Sutil Force India 1:22.346
14 Jenson Button McLaren 1:23.166
15 Nico Hulkenberg Sauber 1:22.389
16 Valtteri Bottas Williams 1:23.260
17 Pastor Maldonado Williams 1:23.318
18 Giedo van der Garde Caterham 1:24.661
19 Esteban Gutierrez Sauber 1:22.793 *
20 Jules Bianchi Marussia 1:24.713
21 Max Chilton Marussia 1:4.996
22 Charles Pic Caterham 1:25.070
http://www.planetf1.com/driver/18227/8706565/Massa-and-Gutierrez-penalised
McLaren opted not to run its latest-specification front wing in qualifying for the Spanish Grand Prix because it did not have the chance to check it would pass the FIA's bodywork flexibility tests.
A pair of new front wings reached Barcelona overnight, but ahead of Saturday morning practice the decision was made not to risk running them without checking.
"It was very tight," said team principal Martin Whitmarsh when asked why the new front wing design was not used.
"We were unable to be confident that they complied legally and we took the decision that unless you are confident in the compliance of the wings then you shouldn't use them."
McLaren had hoped to test the flexibility of the parts on the FIA test apparatus but did not get the opportunity to do so before free practice.
While the wings complied with the regulations when tested in-house, the team did not want to leave itself open to disqualification should its tolerances have been incorrect.
"You will see people queuing down at what is known as the 'bridge of doom' and it's the tests that go on there that determine whether the car is legal or not.
"We and other teams test parts before they are here, the tolerances of stiffness and dimensions is very tight.
"Everyone does their own test but everyone tests on critical issues on the FIA equipment.
"If you can't do that, given the tolerances, you have got inherent risk."
Whitmarsh did not blame the FIA for not being able to test the wing, accepting that the apparatus did not have to be available to McLaren when it wanted to use it.
"The hope was that we would have the ability to get onto the rig but in fairness to the FIA, they have got no obligation to make it available to use early on a Saturday morning so there is no criticism of them - that was the chance that we took.
"Without that check, it wasn't prudent to go forward."
http://www.autosport.com/news/report.php/id/107364
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
