Daniel Ricciardo is the Toro Rosso driver leading the race to step up to Red Bull next season, according to his team boss Franz Tost.
Earlier this month, Red Bull advisor Helmut Marko gave his support to Ricciardo, saying he is the "better" driver to replace Mark Webber should the 36-year-old leave at the end of this season.
Ricciardo has proven to be Toro Rosso's best driver in the opening stint of this year's Championship, scoring seven points to Jean-Eric Vergne's one.
Added to that, the 23-year-old has also outqualified his team-mate four out of five times while also securing the team's only top-ten grid position of the campaign.
"Well, performance is all that matters and you definitely can see that Daniel with 11 races more under his belt - which is more than half of a season - is probably in a better situation," Tost told the official F1 website.
"Right now he has the upper hand, which we have seen in Barcelona. But that is a snapshot right now. Generally I would say that both would fit into the Red Bull concept."
However, the team boss has mixed feelings about whether either driver is ready for the job.
"At the moment I would answer with a 'yes and no'.
"Both would have to demonstrate an exceptionally good second half of the season, because don't forget we are speaking about the World Champions, so the requirement profile is quite different to being with a team like Toro Rosso.
"But don't get me wrong, both are on a very good path and everything will depend on the next couple of months as to whether one of the two of them - should the need be there - qualify for Red Bull Racing."
http://www.planetf1.com/driver/18227/8715788/Tost-Ricciardo-topping-the-list
more good news!
New twin turbo v6 NSX sounds a bit cooler. Actually having said that, wasnt there a new NSX in the works with electric front drive and mechanical rear drive? What ever happened to that? Lol
coming 2015!
Honda could supply a second or even a third team when they return to Formula One in 2015 as their deal with McLaren is "not exclusive".
http://www.planetf1.com/driver/18227/8717061/-McLaren-Honda-deal-is-not-exclusive-
http://www.autosport.com/news/report.php/id/107462
I was thinking something more tacky, maybe something like a Carla Zampatti Laser.
So we've had the Williams-Renault / Senna revival
Now Martin needs to get Bruno's management on the phone sharpish so we can have the McLaren-Honda / Senna re-up for twenny-fifteen...
you want them to lose that badly?
:rolleyes:
I don't think it will be "crank it up" in the old 80s sense of the turbo cars. I don't know the details, but I suspect boost will be static, leaving ignition and fuel mapping to be tinkered. Pretty much like the cars of today, plus theres that bigger percentage of power delivered by kers.
Dead right but, they won't be throwing fuel out the exhaust just cause fans want it.
The only limit on the new engines is basically fuel. They are only allowed to carry a certain amount of fuel and it means they will have to be pretty conservative with boost and power if they want to make it to the end of the race. Hopefully they will hot them up to serious power then turn them down for economy but at points of the race lean on it for more power and speed...strategies will be interesting
So they are regulated to 15000rpm, and a specific fuel flow rate for 2014.
Whoever makes the most efficient engine that can run the most air for the specific amount of fuel wins. Lots of lean burn work going on I guess.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
