In response to a call from the pit wall at the 2006 Brazilian Grand Prix to let Williams team-mate Nico Rosberg pit first...
"Don't think so mate. Britney's in the wall"
yep
anyone want a good laugh?
read away.
Rumours that Kimi Raikkonen will return to Ferrari next year is gathering pace with a Finnish paper claiming it's a done deal.
Mark Webber's decision to quit from Formula One at the end of this season has opened the door for a game of musical chairs over the next few months.
Red Bull initially announced that Lotus driver Raikkonen as well as Toro Rosso duo Jean-Eric Vergne and Daniel Ricciardo were on the shortlist to replace Webber, but Ferrari's Fernando Alonso has also entered the fray in recent weeks.
Although double World Champion Alonso has a long-term deal with the Scuderia, Red Bull team owner Dietrich Mateschitz is apparently eager to bring the Spaniard to Milton Keynes where he will partner with Sebastian Vettel.
With Alonso now appearing to be Red Bull's number one target, Ferrari have reportedly turned their attention to Raikkonen.
The Finn drove won his only World Championship during his debut season with Ferrari in 2007 and he drove for them until he was paid off at the end of 2009 to make way for Alonso.
According to Ilta-Sanomat, their sources have confirmed that Raikkonen has decided to move back to Ferrari next year.
http://www.planetf1.com/news/3213/8870041/-Raikkonen-Is-Going-To-Ferrari-
sure he is..
:rofl::laugh::rofl::laugh::rofl:
...and RBR buying out the Spaniards Fezz contract. I cant see this happening as no way Fezz woudl allow Alonso to compete against them in another car next year. Alonso woudl have to forfeit a lot of money and it woudl have to be covered by RBR. Not going to happen...not for a guy that is likely to cause political tension in the team...hell more than Webber did.
Kimi woudl be plain sailing...Alonso not so much. But if it does happen says a lot about the Vettel to Fezz rumours!
Which number one driver would join RBR to be Vetel's bitch? Its not the same situation as Webz who was in there first right? They would be joining a team with an established onlgoing WDC runner. You think Kimmi would be able to take that much spunk on the chin? Even Kimmi would throw it up an start laying into Seb.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
    • street use or race track, what hose size and why? what factors change with the hose size options ?   see most comon is an10. when you see most oem external coolers are closer to an12? does high volume oil pump like nitto need an12 or 10 be just fine
    • The rod I was moving left and right you can see looking from the passenger side floor up into the center console.  IMG_8095.mov
