Vettel is cleanng up his new rubber latex bondage suit and rubbing his hands and peanut sack and loving the fact he has another aussie to ram his 3inch knob into.
Big mistake for Dan. He is now the new official Barrichello.
Would much rather have seen Kimi there as he would have floored the little top bloke vetstool.
Off to Japan F1 next month. Will be boring as hell but I only go for the beer and Japanese candy.
So many writing off Dan before he has even lined up for a single practice session in the same car on the same weekend. I am not convinced it has been done purely because the expectation is that he will be a lap dog.
I think he has real pace...if RBR wanted to make their lives easy they would have canned Webber 2 years ago and put in any number of drivers like Di Resta, Hulkm an STR Jr etc. Webber has tried to give as good as he has taken and the team has hardly been harmonious whilst he and Seb have been battling.
I think its too presumptious to think that RBR want a lap dog and No.2 by definition. If Dan cant keep pace then he will be a No. 2 by default not by design. The other big reason why I think they need to put someone who will put it up Vettel is that by the end of his cotnract he will have been there 7 years! I think he will be looking for a change/challenge (provided the other team is competitive like mercedes or Ferrari) if he gets bored at RBR. And a young guy beating him will keep him interested and motivated.
Kimi, based on his behaviour at Ferrari doesnt always stay all that motivated when things are not going to plan
Depends on how much Tool can dictate terms to RBR doesnt it? Hoping Dan is like Webber in respect to not putting up with sh!t from anyone. Hoping he is not like him in terms of being able to get a car off the line.
Fingers crossed it goes well. Because other than some young bloke by the name of Brabham I cant think of where the next Orstraylian GP driver would come from.
it looks like he's focusing on indy.
for now anyway.
I'm not writing Dan off before he's started, but the facts are these:
Dan is not outscoring his current team mate. Not last year, and again this year. I don't think the three, soon to be four time WDC will be terribly worried in terms of the championship.
Dan appears to be a good qualifier. Problem is, Webber was also regarded as a very good qualifier... I wouldn't rate Dan as better than Webber in that regard. Maybe he'll prove that wrong, but I don't think so.
Webber is also a very good racer. I would definitely rate Webber's racecraft and race pace as significantly better than Dan's.
Dan does have one thing on his side, and that's the potential to improve.
Edited by hrd-hr30
Roy I'm knocking Dans ability but with Dietrich and Helmet head at the reigns and a German World Champ then Dan needs to learn how to say woof !.
Hope it's a different scenario but after 30 plus years of following F1 just looks the same old same old , just a different lap dog.
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
