Like Deca? Wish It Were Closer? Wish No Longer! New Skid Pan In Melbourne!
RTR - 'Road Track Rally' have delivered...... baller style.
Yes, you're seeing correct. A 9000 sqm (i believe) skid pan VERY soon to be available in western Melbourne. Prob 30-45min'ish for those of us on the civilised side of Melbourne :D
Slightly smaller than DECA overall, but i think maybe a little longer... not 100% sure
Not April fools, this is full legit, ready to rock early 2013!!! Bring it!
oooooooooooooohhhhh yeeeaahhhhhhh.........
  • Replies 76
Like DECA?
I see no back track :huh:
As said in the other thread (might have been wasteland), hopefully it doesn't go the way of Drag Tag's skidpan that ended up having the Law sitting out front of it all the time. Although it wasn't built as a skidpan given the main business is Forklifts... So council likely don't know it's going to be used for "that"...
oh yeah, no back track, but 'like DECA' i meant is in the 'affection' variety, not necessarily by it's exact make-up. But still, great to have an autocross venue close by - google tells me 45mins
public events? as long as there is an event you can join, then that's all we need. SAU DECA aren't exactly 'public' events, still need a CAMS/ASAA (or aasa whatever) license. I'm guessing it will be along those lines
i'm sure this is a multi-purpose venue, but will cater for motorsport events.
If anything, this will be a good compliment for DECA, you can do these events close-by but if you want a day mixed with some tight track action, you can go for a DECA.
hahaha, yes Grant, no armco :D
Ye that's cause it's all 100km/h sans the Westgate section :thumbsup:
It's still 25mins from the CBD regardless was my point, as it's being claimed as "10mins", which is just rubbish as it takes 10-15mins to get the the WGB from the CBD - i do it regularly
this isn't a workshop war thread, not that there is one going on, this is just to let you know we all will have a DECA (skid pan) sized facility available to us for autocross events. That's it, we should be all grateful for having motorsport facilities closer to us... isn't that what we've always called for? Yes it isn't another metro track like Sandown, but good luck that happening. And no there isn't a back-track like DECA, but it's still potentially a great facility to have some safe fun, that's pretty easy on the car.
10-20mins whatever, all i know is that more close motorsport venues the better, no?
You must drive slow I regularly do point cook / hoppers crossing to city in 15-20 mins
    • Today, I'm a Breville BES920 tech, new triac board and new 3x way solenoid. Had overheating issues, home RCD tripping when it got warm, and the boiler stayed on when the machine was shut off. Also, usually 3x way solenoid chatter, this is the 3rd time I'm replacing it. Mind you, this machine is 9 year old and send it every day doing at minimum 3x double shots. When the in laws come over to took after my daughter, it will easily see 6x double shots in a single day. Tried to be somewhat compliant, crimped and then used a screw connector over the top. Would have preferred to use heat shrinks.   After all that, turns out all the overheating has damaged the o-rings to the steam tap as well. Ordered new ones, coming soon.
    • Still got it- First time checking sau in a while ahhaha
    • I don't know about that. I can hoon my R32 around - hard launches, high lateral Gs - with <<1/4 tank without any such shenanigans. This with the previous 040 and the current GSS342. I would suspect a fuel line problem. One of the hoses associated with the top of the tank perhaps.
    • This is amazing. Love that you’re giving the boys an intro to cars and off the screens. They probably have an insta for the car and build posts on TikTok for their mates.
    • It is.  Your car works fine with the tank full. If you drive like a Nana it works fine.  You give it a boot full with half a fuel tank, you get surge.  It 100% is a fuel surge issue. Maybe have a look at installing a Hydramat if you don't want to install a surge tank.  https://www.holley.com/products/fuel_systems/hydramat/
