Originally the stroker kit came with shorter rods so an off the shelf piston could be used.
We scrapped that idea and decided to use an off the shelf rod (longer) with a custom piston.
A longer rod Improves rod to stroke ratio and reduces wear on the thrust side of the cylinder. A custom piston also allowed us to decide how much valve relief was cut into the top as the UNIGROUP cams have big lift
So you are staying with the EU 260 10.8s
I am glad I know shit all about cars, it gets too technical when you want to push the motor :(
You blokes made it an easy decision for me, I thought what was the easiest way to get what I want from my car without knowing all of the technical stuff, I went with with the stroker build and I did not have to take anything off the car that I spent money on , except for the Poncams B, I have kept everything else under the hood.
Edited by Nismo 3.2ish
Add these to the handling mods
they look like those crappy Yokohama AD08Rs, my flip flops have better grip :) well in the dry
The 2.6L 8374 equipped missle i went in today certainly sealed the deal with everybody that went in it.. Including some pretty hardcore #twinturboGTR4lyf mofos! They even buried the notion of needing 2 turbos for response in this wonderful age of lightweight billet materials and black magic aerodynamics that make 1 turbocharger enough to tear ya face off from 4000rpm to redline (in 2nd gear) from a 800hp turbo :)
Do you know what rear housing this car had? If it's the same car that Piggaz mentions a few posts on, sounds like it might have been the 1.05 (external gate)? Sounds pretty interesting, I had always thought that a 1.05 rear housing on a 2.6L was quite large and potentially laggy but perhaps technology has come a long way in the last few years.
It was the 1.05.
I had the same thoughts in my head before I got in it. Yes it had v cam BUT it also had a F con v pro which was half assed tuned on a 37 degree day. I can't see the point in going back to the 0.92 IWG, it went that well.
So much untapped potential that's for sure.
Starting to be a bit of a build thread lol
New modified cam and front covers.
Race pace extended sump and quaife front diff to go with the stroker
Threw in a new dash and cluster cause the other ones were feked
Before and after, the mrs gave me a hand with that last one, was a bit of a long night haha
  • Like 2
  • 1 month later...
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
    • There's not a great deal to report here .... except ...... FOR .... LSD!!!  I bought a Quaife LSD from the UK and shipped it here .... Wish I'd just bought locally cause the shipping and duty was $700! But there were so many diffs used in the E90s I just wanted to be absolutely certain I was getting the right one so I spoke with a supplier in the UK who builds race cars and they have heaps of experience with the E90s.  I pulled the diff out which was seriously awesome - I've never done anything like that before, I must have watched 1000 videos on YT about it as well as consulting the Bentley manual. It was super easy in the end. The diff was delivered to the awesome folks at Hornsby Diffs and will be back in a few weeks. I also replaced the diff bushings with some Nolathane ones.  Really looking forward to getting it back and getting back to the track or even the skidpan.
    • yeah... the 13kg/mm springs weren't always in there, I had 10kg/mm but doing a few SMSP commanded heavier front springs. It's so good now going into T1 and T2, just need more seat time and real tyres.
