Hi all,
I've just about completed what I consider to be an entry level track setup on my 32 GTSt. Just wondering whether this will be enough for the car to handle well enough for a beginner driver. All comments welcome...
BC Racing Coilovers (8kg front, 6kg rear)
Whiteline subframe bushes
DBA 4000 front rotors
Optima Front pads
HICAS lock bar
Brake master cylinder stopper
Remapped ECU with Nistune chip
Car puts out 222kW on 18psi with all supporting mods and is tuned for track work.
Cheers
just drive it however it is now, as long as its in good mechanical condition of course. You don't need to complete a list of mods to enter a track day. I've driven my stock auto Soarer at a couple of track days and the only thing done to that is a set of lowered springs. Its just as much fun to punt around the track as my 200rwkw 180SX was with all the mods...
See plenty of people tracking much less car than that, personally, a Camira (it was a rally car, but it had SFA done to it) and a bog stock Mitsubishi Starion. Just get out there and enjoy it, some form of oil control (not sure if rb20s have the same issues as 26s) and cooling would be a great idea for the longevity of your engine though.
Hi all,
Optima Front pads
HICAS lock bar
Cheers
So reading this you have already done these mods?
If thats the case i would change the fluids and add in something to keep an eye on temps and oil pressure if you can then go your hardest, heat in WA can be tough on car so monitor it and you can always take an extra cool down lap if it is a problem and add further mods as you go along.
Good point. Gets hot up here in QLD too. The track day I did last week was 32degrees at the track. I was doing 2 or 3 cool-down laps to get the engine temps right back down and give the auto a rest.
I've been using thermocouple temp gauge/alarms on all my cars for about the last 3 years. Having audible alarms means you don't need to constantly stare at a gauge. Good for everyday cars too - who really looks at their temp gauge constantly on a highway run? You can set the alarm levels to whatever you want. Being thermocouples, they still read a proper temperature if you've lost coolant, whereas normal gauges just don't work if they're not immersed in coolant. Quick and easy to hook up, with no need for those dodgy in-hose temp sensore adapters which add in 3 extra potential points of failure. And can control thermo fans as well, with user defined on and off temps.
32 GTS-t at that level, you don't need an oil cooler unless your sprints are 25 laps plus (even if the ambient is well into the 30's). Just over-fill it by one litre and she's good to go.
Mine is living proof, using Castrol Edge 10W-60.
Edited by Marlin
What about a harness. I've done one track day in my XR6 Turbo and it was horrible trying to stay seated. I'm about to take my GTR on the track for the 1st time early next year and was wondering how much of a difference a harness makes?
The falcon seat will suck teh balls in comparion to the GTR one.
But a proper seat and harness is a whole other deal.
depending on rims/tyres a power steering cooler wont go astray either
hhhhhhhhhhWhat?!?!?
No need. Just stop topping it up after the Resevoir has a spit and gurgle. It'll find it's own level.
None of this is ground breaking info here.....
Cheers mate. The gtr seat is a shit load more supportive than the old falcon one. I guess i'll try a day with it standard and if i find i need more i'll grab a seat and harness combo.
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
