G,day, Ive been using my R33 GTST for superspints and drag racing, problem is my gearbox has stripped the case hardening of the gears, Ive been told that due to launching and prolonged high G high power (380ish killerwasps) loads the oil in the box gets pushed back and has starved the gears of oil thus damaging them, the oil was Hi-tec and changed every 5000k or so and was at the fill point..
Im going to buy a new box from just jap and want to know should I over fill the box a bit, Im also going to put in some Nulon SYN75W90 and Nulon G70 in it as well.
Unfortunatly I do not have the funds for dog boxs or stuff like that, my max cost is around $3000 for the box and oil and other stuff to get it installed.
Any help or info will be much appriciated.
Thanks, Mark
https://www.sau.com.au/forums/topic/414977-gearbox-oil-level-question/
my info is that you are a very lucky man to have had enough motorsport to wear out a gearbox.
let's face it....some stuff wears out. I'm onto my 3rd box in 8 years. The brand new one I bought lasted OK, but rebuilt second handies have been just as good.
take it to award gearbox and diffs, those guys are cheap and actually know their shit with skyline boxes.
BTW no point overfilling the gearbox, it will just froth up and flow out the breather.
Thanks Duncan, my problem is to rebuild it would cost almost as much as a brand new item. $2700 for a new one, or $1500 for rebuild but I need new gears which from my nights of googling are around $1000, and second hand boxs of unknown condition are over $1000.
Seems like I need to win Lotto or stop thrashing the car, Ill wait for Lotto I think, thrashing the car is so much fun.
New box 3k
Giken cluster installed 5k
Personally I overfill mine about 700 mills
When on long track sessions ( longer than 20 minutes at a time) any more it spits out any less it comes out as smoke.. Happy median
Thanks mate, also who is this" Barron " with the Nismo diff stuff, and does he install, I want to be not gay and chip on roundabouts.
Mark
Baron was Beer Baron, so named because he used to bring beer to all the SAU meets. Or you could call him Richard. In any case, it's just about adding some extra clutch plates to the diff. Award can help you with that too.
Lots of people may disagree with me...but I reckon you should check out a PAR gear set; they are fine for medium duty track use, heaps of race cars run them in the state champs.
it's not cheap...unfortunately the faster you go the more it costs.
Didn't Richard also have the ability to be the one inside the barriers at the Nismo Festival in Japan taking pictures and talking to people when mere mortals could not get within 100 metres of the place.
I'm getting it rebuilt at Award gearbox and diff, they will replace everything with new and do a internal mod to help with the oil feed to the front, diff might get some shims as well, works out the same price as the new box but get better syncros (series 3 I believe)and the oil mod so I've got to be happy with that.
Mark, I have a box here if you wanted to have a look at it. I wasn't real impressed with friction modifiers in the box and changed to redline and was quiet impressed. Can get it cheap from gllubricants.
Not sure if you could look at modifying the baffles and making them smaller without stopping too much flow back but could be worth a look.
Hasn't redline got something in it that makes it stick to the gears to hep prevent it going dry as yours has...
I remember seeing a photo of a box or a diff that had blown its casing and you could see the oil still stuck thick to the gears..was quite amazing..
Just not 100% if it was redline or another oil..
Mark, I have a box here if you wanted to have a look at it. I wasn't real impressed with in the box and changed to redline and was quiet impressed. Can get it cheap from gllubricants.
I"ve heard that Redline has a new formula that foams up or something, I"ve used it before but ATM I"m scared off it.
I actually just put in the last bit of some shockproof I had lying around, about a litre, LOL, the box still sounds like a grinder.
What didn"t you like about the friction modifiers ? they sound good in the advertising, but then everything sounds good in a ad.
I"m quite willing to pay for any oil that has the extra protection benifits.
Mark, I filled my box up with surfs blood just before three nationals. No issues with it spewing its guts up on the track or on the street.
Plus one for award. Terry is a top bloke!!
Sound good then, I might get some engine oil,gearbox oil, diff oil and waterwetter from them and give the whole range a try.
I just need to get the thing fixed ASAP to get the Minister of War and Finances of my back, again......
  • 4 weeks later...
Started getting some crunching 3rd to 4th today :(
I am thinking to late to try shockproof now, not sure I can get any local so would have to order some
Worth trying or am I also now in the market for a Box or a rebuild, how much does a rb26 box take 2.5ish litres yeah?
car was sposed to be getting light track/drag duties again this year
would be nice to get a trouble free year, I heard that was possible :whistling:
Edited by noone
My gearbox was rebuilt and modified by award, the only original part was the case, everything else was new parts, the mod put a plate in at the rear of the box to stop the oil running back there, the plate has a hole to let some oil get there and for its return so the area does see oil.
There was also some pipe work inside to help flow the oil out too the front of the box.
In the end the box took 4 ltrs of Nulon Full Synthetic 75W-90 Performance Smooth Shift Manual Gearbox and Transaxle Oil with 250ml of Nulon G70, Award said this would be a excellent mix.
On a side note my Coppermix clutch was as newish still, finally a bonus.
Geez okay thats more than i thought so one gallon bottle of Redline light weight Shockproof wouldnt be enough
One Gallon (4 Quarts = 3.784L)
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
